Page 2 of 3 1 2 3
I
I
Originally posted by chknhwk:
Buckshot, everything looks good but that TB. Is that going to be big enough?
Yeah, Buckshot. And what size MAF are you going to use?
99 Range Rover 4.6 HSE
Mystery Car??????
I'm pretty sure the TB will be big enough (plus it was free) if not, I can always sell it off and stick a 70MM on there. Besides the UIM can only be hogged out so far- ask Brad with his 70MM. As far as a maf goes- 80MM with the post cut out.
For those on injectors, the reason I'm going 42lb is that I'm not going to use the vortech fmu to boost my pressure up to 80 psi until I have to and by then I'll have replaced all the stock rubber connections which aren't safe at that level of pressure. 42 is what all the math calculations came up with for our projected HP output of 400+ at the crank. Our eventual goal by the end of summer is 500+.
Stock rods are one of the known weak links in the engine. The pistons themselves are pretty beefy.
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
how much was the custom rods? i saw the pics of them. think they will make more?
Michigan CEG BenTonEdge@aol.com
**DEAD** Dec26 01. 96 2.5 Gl dessert violet. mystery mod, gutted cat. no res. craked secondaries. custom air box. And a good old CEL Oh you want to know
Originally posted by chezterr:
Until I see proof for another option I will be doing this:
3L Short Block
2.5L Heads (Aggressive Port and Polish) with 3L
Valves
SVT or Custom Reground Cams
SVT LIM
SVT UIM
65MM TB
I feel that if you are going to build up a 3L, you my as well have your heads P&Ped to free up even more HP.. It will be worth it in the end...
Nikolas
My setup to the T...EXACTLY!..
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
W
W
I hate to say it, but nothing is cut-and-dry with this. Like all things, you have to take a compromise. The SVT manifolds themselves are a compromise that allows good airflow velocity at low and high rpm.
I try to remember it this way. The small tubes will have a higher flow velocity into a given cylinder than a large tube. However, the small tube has more resistance to flow and will not allow the same volume into the cylinder as a large tube.
So you have to choose which area is important.
The SVT manifold should keep low end torque high and flow well enough at high rpm to keep the torque high there as well.
The 3L 01 plastic upper and lower manifolds are obviously larger, and will flow more air. However, there will be a loss of flow velocity at the low end and therefore will likely be a reduction in torque. On the other hand, the high rpm's should see more torque because of this.
I choose a wider flatter torque curve, so that is one reason why I am happy with the combination that I used.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
Couple of points.
1) if going to 35mm valves with either 3L heads or 2.5L with porting and 3L valves would have the upper intake Extrude Honed to about 34mm as well (stock SVT UIM is 30mm primary and 32mm secondary). No point in having big valves if runners are to small. 99+ SVT lower is already 33/34mm.
2) the 35mm valves on 3L are proportional to the 32mm valves on 2.5L. Substantial gains going to 35mm valves on 2.5L (all the touring cars do this) so the HOT set up for 3L may be about 37mm perhaps. Maybe worthwhile if really going all out to have custom 37mm valves made.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
starting 01' the LIM was siamised along with the heads. there are only six ports on the new 3L and no IMRC.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Actually, in doing some research, I came in contact the the engine builder for Leo Capaldi's Cougar..... he owns Kinetics in Michigan...
I asked him about larger valves in a 2.5L, and he said they chose to use the stock valve sizes in the 2.5L engine because the larger valves got too much in the way of the piston and/or cylinder and what not, and they didnt see any gains.... I found this bit of info to be interesting, to say the least....
Someone may be able to offer a more scientific explanation as to why larger valves in the 2.5L engine may not work well...?????
Nikolas
1999 Mercury Cougar V6
KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Ben, you ever find a motor to work out? I've still got that 2000 one for sale if you're looking. As far as rods, they set me back $1100 for the set. BNM is looking into possibly having some made so stay tuned.
Rick
Many Mods
Buckshot77@aol.com
Totalled on 10/7/01
SVT Parts for Sale
Not a bad way to spend $10,000 wink LOL
Page 2 of 3 1 2 3
