Posts: 115 |
I have read all the posts, done the searches, but no one puts it out cut and dry.
What will flow best. Take all the combinations of 3.0 heads (all years) and 2.5 heads (svt and non-svt), as well as all possible Upper and Lower intakes from both engines for all years, and all the different cams.
Now which system will flow the most air at the best velocity. I don't care about hood clearance issues, I just want to know what is the best setup.
What I *think* is the best, but I'm sure someone will correct me is:
2001 or better 3.0 heads 3.0 valves SVT cams SVT LIM SVT Dual Honed UIM (although that wall after the TB kinda bugs me)
btw: i would rather build an engine that makes HP at mid-high rpm.
2000 Cougar V6 MTX Black Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more... See Her Here
Posts: 460 |
Until I see proof for another option I will be doing this:
3L Short Block 2.5L Heads (Aggressive Port and Polish) with 3L Valves SVT or Custom Reground Cams SVT LIM SVT UIM 65MM TB
I feel that if you are going to build up a 3L, you my as well have your heads P&Ped to free up even more HP.. It will be worth it in the end...
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 7,329 |
Originally posted by chezterr: 3L Short Block 2.5L Heads (Aggressive Port and Polish) with 3L Valves (Compression dropped to 10.8-11) SVT Cams SVT LIM (No Secondaries) SVT UIM (opened up) 65MM TB I like it...
Posts: 54 |
My thoughts are very similar, with the exception of the heads and LIM. The new 3.0s have 1 oval port per cylinder rather than 2 circular ones. Of course I have no evidence to what actually flows better, but I know of at least one race motor with its intake ports 'siamesed' for better flow. Just thoughts. Mid-to-top end power is also my cup of tea. Oh, and I mention the 3.0 heads because it's less prep, plus the 10:1 compression is fine, because I would plan on adding +/- 50 shot of nitrous as well. 11+:1 would not be fun for long.
'99 Cougar V6 5spd - I/H/E, Koni/GC
Posts: 1,611 |
Here are my specs that will be dynoed in the next month- 98 3 liter block and heads SVT cams, lim, uim custom rods (stock size) vortech S/C with smaller pulley 42 lb injectors 65mm TB Hows that sound?
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
Posts: 54 |
Hmm, no shortage of fuel I'm sure! Are the stock rods weaker than the pistons? How much boost are you going to run with? Any bets being made yet on what that puppy is going to put down?
Posts: 1,447 |
42 pounders  Think you'll need that much fuel? What else you plan on doing with the fuel delivery, new pump and lines to deliver enough to those badboys. I am gonna stick with the 24#'s that come with the 01 3L, if push comes to shove I can swap them out at a later time.
Posts: 539 |
well im goin to the dyno on weds and i can show you what a 3L with 3L heads ported and polished with svt cams svt lim/UIM can do. The rest of car is stock except kkm.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 115 |
Ok i know the 3.0 lim is siamessed what about the heads, at what point to the go back into two ports for valves, right where it meets with the lower or a little bit down thanks to a nice split, basically what i'm asking is going from the lower to the heads is it nice and smooth?
Posts: 1,151 |
Buckshot, everything looks good but that TB. Is that going to be big enough?
ChickenhawkRacing@hotmail.com 1998: #4415/6535 mods: Sheet metal screws in rear chrome strip Four wobbly corners "Hey, do you like apples?" "Well, yeah." "Well, I got her number, how do you like them apples?"
