Page 2 of 4 1 2 3 4
#403684 02/20/02 04:22 PM
W
W
Good catch Brad.
I've been checking on that. I've been told the valves are the same material, but then also told by different people that they are different material. I will edit the above post about that.
I can find no one who really says anything for sure. I think that I will go ahead and take the two valves into school and try to perform some analysis on them.
thanks again,
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
#403685 02/20/02 04:29 PM
IIRC, Terry replied to a post about that with knowledge of what they were made out of. I don't remember what they were made out of or if they were filled with powder or hollow, but the info was there. I do know he was against it. I'll see if I can find it...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#403686 02/20/02 04:51 PM
Here it is...
Exhaust valves are a higher temp matl (Nimonic) .They operate at a higher temp than the intakes,which are cooled by the incoming charge.In most conditions the exhausts operate with a slight 'glow'so they must resist oxidization better than intakes.I would not use intakes in place or exhausts...'The China Syndrome....'core melt down'...
From this topic: http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=49&t=000089
Brad Noon
'99 SE MTX
#403687 02/21/02 05:09 PM
F
F
My setup will be 3.0L block...SVT heads/cams with 3L valves. I will try to get the compression just under 11 if possible..
Thanks
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#403688 02/21/02 05:24 PM
Thanks
Eric
Don't forget a chip for timing control.
#403689 02/21/02 08:17 PM
F
F
Well I've had bad experiences with the superchips..I will have the apexi..but I might try the diablo...I have the SFG2 code with has been somewhat widely tuned so hopefully it will work out..
Eric
#403690 02/21/02 09:10 PM
You are going to need custom programming for the timing if your experience is the same as mine (PCM timing too agressive for 11:1 compression and knocks like mad). A custom burned Diablo is ~$200 cheaper, so that's what I am going with (soon, very soon). $510 for custom Superchip, $325 for custom Diablo. Mine will be RLJ1 code.
#403691 02/22/02 06:59 AM
H
H
so its possible to get 240 fwhp out of a 3l swap/mix? is that like 270hp at the crank? i wanna be all over that (less the turbo, dont have $5000). what would be a rough price to reach this?
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#403692 02/22/02 08:25 PM
Administrator
Administrator
The only one who has achieved 240hp (David Z) has special, one-off SVE cams. I doubt you could get there without them... slap me if I'm wrong.
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
#403693 02/24/02 01:27 AM
H
H
warmonger was able to reach 217 fwhp which is hella good. if i just did my math right assuming the 17% loss, thats about 260 hp at crank. i'd be more than pleased w/ those results. just curious what cost of getting to this level is versus the turbo. I would prefer to have a n/a engine.
very nice 3l explanation in your site warmonger.
AIM:omegazodiac
95 gl
built 4/6/99
black/tan
Page 2 of 4 1 2 3 4
