Here's an opinion for the archives... I know, its another Mamoth post (trademark).
I have finally decided to make a recommendation on this. I have done lots of research and work on this very subject, and I can make a reasonably educated guess as to what will give 200-230 HP to the wheels with minimal cost. Here follows the "Formula" that I think will work best.
-- 3L block.
-- SVT heads with the following:
1.) 3L valves at a minimum along with minor porting to smooth everything.
2.) VERY moderate to light porting of the primary intake runner from the upper intake manifold all the way down to the valve in the head.
3.) Heavy porting of the the secondary intake runner from the upper intake manifold all the way down to the valve.
4.) Small adjustment to the combustion chambers that will yield 10.5-10.8 compression ratio.
5.) Heavily ported exhaust ports and exhaust valve "bowl" reshaping.
Optional: You MIGHT be able to use the 32mm intake valves as your new exhaust valves along with appropriate porting (I'm checkin on this now). Either way, if you can find 32mm exhausts, then I think this along with the higher compression will yield GREAT results.
Exhaust:
--headers and y-pipe with a 180 degree bend such as MSDS.
--Gutted precats in factory manifolds (appropriately ported) and a better y-pipe or optimized factory y-pipe (like I have done).
-- Standard manifolds that are appropriately ported and the optimized factory y-pipe or a better y-pipe.
--2.5" custom catback exhaust.
With this you should be able to run the stock PCM with no problem. I HEAVILY modded my primary intake runners and with the open exhaust I ran into a lean low RPM condition. The pcm is more than capable of compensating for the extra airflow at high RPM.
With a tuning device such as the APEX SAFC, you can do the heavy porting and be able to tune the airflow with it.
If this new GReddy eManage piggy back air/fuel/spark management computer turns out to be a good product, then you can count on being able to compensate for any mods you do and should add it to the shopping list.
I am not against using the 3L heads, I just think that there is some nice benefits to higher compression for those not using a S/C or turbo, like very quick throttle response, and excellent low rpm torque.
warmonger
