Panther and anyone with the issue.
I have been doing a little more Diagnosis and I have found something new.
When the car is very cold, 1st startup of the morning, I can take it out on the road and for maybe a mile I can accelerate without the stuttering. After that its all she wrote. I checked the coolant temp, and it was in the 120's degrees F that the car was running smooth. Above that it began to stutter and it got progressively worse as both the air and engine temps rose.
I think that any 'tricking' test should be done by controlling the resistance to the coolant temperature sensor going to the pcm. NOT the gauge. The coolant temp sensor is a two wire plug that you can pull off and stick a fixed value resistor in it to see what will happen.
The sensor is located on a crossover coolant pipe right below the throttle body.
I am going to try this soon. You can also use a poteniometer with two wires soldered on to it, and then you can use your OBD scanner to watch as you adjust it to the proper temperature.
Test several temperatures so that you can find the point that the stuttering goes away.
If enough of you can successfully use this approach to clarify the temperature that the stuttering goes away, then we can compile the data and you can go to Ford. This may get you a new calibration for your computer because there is a certain amount of fuel enrichment that the computer does when the engine temp is low. This evidence is surely a good way to indicate to Ford just how lean the engine runs below the IMRC opening point.
If ford doesn't want to do anything, then the best advice is to get the APEX SAFC, or a new MAF with an optimizer. If the test works on my car, then that is what I will do. There is no way in hell that my car will be warrantied now!
Apparently this is a lean-misfire condition that happens below the IMRC point because the IMRC point is a signal to the PCM to richen the fuel mixture.
Please past a link to this page to your buddies with the same problem so that they can test this theory also before they do any other circuit design.
