Posts: 305 |
I'm thinking about trying to get the throttle body and MAF off of a junkyard Mustang. I've got an S-AFC to tune with, but I'm not sure what would be the best model to pirate from. Has anybody else done this?
'00 CSVT #570 - 3L
Posts: 5,805 |
Talk to NYNicks,I have his 'stang body modded,the upper part of the egr casting is exposed & causes a leak on the manifold so its not a straight swap....
Posts: 3,562 |
What year stang TB is it Terry? Haven't had this problem with my 70mm BBK one from a '00GT...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 7,329 |
96-00 4.6L 2V Mustang or Crown Vic 65mm TB's work just fine when modded properly...
Maybe the newer ones too, but those years for certain...
Posts: 305 |
What size MAF do they use? I was wondering if it would be practical to try and grab an entire intake.
'00 CSVT #570 - 3L
Posts: 3,419 |
Originally posted by A2Steve: What size MAF do they use? I was wondering if it would be practical to try and grab an entire intake. Since you have a Ford 70mm MAF, if you wanted to upgrade in size, you need to grab one off a Cobra 4.6L 4V. They also come on the Mark VIII and I think one of the pickup trucks (maybe).
Posts: 305 |
Thanks, that's what I wanted to know.
'00 CSVT #570 - 3L
Posts: 2,481 |
Originally posted by A2Steve: Thanks, that's what I wanted to know. While you are at it, if they have another in one of Detroit area bone yards, please pick me up one too.
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 460 |
Check this out... a list of upgrade OEM MAFs....
Car year Size part # Stock Fuel Injector Size
Mustang GT 96-97 80mm F50F 19lb Mustang GT 1998 80mm F8LF 19lb F Series 1998 80mm F8LF 24lb Expedition 1997 80mm F50F 19lb Expedition 1998 80mm F8LF 19lb
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 341 |
You would'nt happen to have infomation like that about throttle botties now would you?
Yankeyspeed: American power and ingenuity 95 SE -Stock enough Yeah my car has a baby seat, its still fast.
