Posts: 277 |
Just click on this link for a good laugh! http://www.fordcontour.org/cgi-bin2/ikonboard.cgi?s=3c6378ca7f10ffff;act=ST;f=32;t=3 Just remember that the car is going into the paint booth next weekend and will begin to be pieced back together soon there afterwards. Look for some interesting suprises in the very near future.
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound Administrator www.fordcontour.org
Posts: 1,003 |
Holy Cow! I havn't seen a car like that since I passed thru Hunts Point in the Bronx! Talk about stripped down.. Can't wait to see how it all comes back together.
Alex in Boulder, CO 95SE MTX 157hp 151tq before latest mods...
Posts: 3,562 |
I haven't seen a car like that since... well, since the other day at Buckshot's house... :p We'll be sure to get some pics if the sawsall action when all of the "good" parts are off of the car.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 2,246 |
Are you sawsall'n the old SVT?
David Litsky AIM: DaveL225 My Car
Posts: 3,562 |
Posts: 1,050 |
I can't help but reiterate the point I made before so that those of you doing the 3L swap can save time and work. Pull the whole powertrain through the top. It is a very simple pull when you do it that way. I can't imagine spending hours underneath trying to unbolt everything connecting the trans and engine together plus miscellaneous crap and having even less room to pull the engine because the flywheel is still on it.
Pulling the whole powertrain took four hours from the time I touched the first bolt till the engine was on the floor, and that was by myself.
Yes I'm thumpin' my chest, but I just don't want anyone from CEG working harder than they have to. Or getting frustrated in the process and breaking shiit. The more work done in the car the more stuff gets ruined.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 3,562 |
If you have the means to drop it out the bottom, it's even easier... I'll agree on the engine and trans out the top being the best way for a driveway or personal garage extraction though...
Posts: 539 |
when i did the swap we did it on a lift so we jsut unbolted the frame from the body unplugged some harnessess fuel lines and lifted the car. even left the struts in place.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
