Posts: 277 |
Please check out the progress being made on the newest 3L conversion in the fordcontour.org forums by clicking on these links...
http://www.fordcontour.org/cgi-bin2/ikonboard.cgi?s=3c54c89a1592ffff;act=ST;f=32;t=3
and...
http://www.fordcontour.org/cgi-bin2/ikonboard.cgi?s=3c54c89a1592ffff;act=ST;f=32;t=2
Thanks, "QWIC"
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound Administrator www.fordcontour.org
Posts: 1,050 |
I can't believe those fools wasted the time to pull the engine without the trans. You can probably save 3 hours by pulling the engine and trans at the same time. That is besides the fact that there are potential bolt-up issues with the hybrid that will be a hell of a lot easier to solve when the drivetrain is outside the engine bay. When I pulled my engine, from the moment I opened the hood till the moment it was being set on the ground with a hoist trans and all took me 4 hours. This is one of the easiest front-drive engines I've ever pulled.
I will give those guys props for courage and originality. I wouldn't have the balls to paint over a beautiful Toreador red with plum purple.
Good luck anyway.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 7,329 |
Originally posted by warmonger: I will give those guys props for courage and originality. I wouldn't have the balls to paint over a beautiful Toreador red with plum purple.
heheh...
Posts: 88 |
I was thinking about repainting my Tour yellow. NO!!! Not becuase I think it will make me faster I just like yellow cars. I was thinking about 99 Mustang Chrome Yellow, what do you guys think? I don't like the newer Zinc Yellow I think it looks to pale. I have only seen one yellow Tour and that was in the Gallery section of that supercharged one. I just want mine to stand out from all the millions of Contours out there on the roads. Mine is T-Red and I think it is very pretty but other the Kendall everyone else has a t-red Contour in Wilmington. What other non-factory colors do you think would look good on a 2000 Tour since I know most of you guys like to bash people painting cars yellow.
2000 Ford Contour SE 2.0L Zetec ATX Removed Air Silencer Added Side MArkers Removed Door Ding Guards ----------------------------------- 2001 Ford Mustang 3.8L EFI AODE Nothing Yet......... ----------------------------------- 1989 Plymouth Sundance 2.5L A/T A whole slew of aftermarket stuff but mainly engine work. The list is really long so I decided to save us some bandwidth by taking it out! ----------------------------------- 1987 Subaru XT GL10 AWD Turbo Removed half the interior in my never ending quest to find the fuel pump relay so I can fix it!!!!
Posts: 1,151 |
If you do yellow, definitely go w/ the '99 yellow. After that the zinc yellow blew. Burnt magenta would look good, check out www.ctamotorsports.com Also I think the steel grey that came out the same time as the zinc yellow would look pretty darn sweet.
ChickenhawkRacing@hotmail.com 1998: #4415/6535 mods: Sheet metal screws in rear chrome strip Four wobbly corners "Hey, do you like apples?" "Well, yeah." "Well, I got her number, how do you like them apples?"
Posts: 277 |
The lighting is simply bad in the pic, the color is still the orginal color not purple. The new color is going to be diamond white metallic, a custom mix with DuPount paints.
Posts: 5,805 |
Who cares about paint..!!!! stick with the 'heavy metal' for the power...
Posts: 1,050 |
Haven't you heard? Cars of today go faster with brightly colored paints than the cars of thirty years ago. WAY back in those days, grey primer was the fastest paint they made....at least it must be because all the hot-rodded OLD cars I see are covered in it.
warmonger
Posts: 1,050 |
Originally posted by QWICSVT: The lighting is simply bad in the pic, the color is still the orginal color not purple. The new color is going to be diamond white metallic, a custom mix with DuPount paints. That's some Damned bad lighting to cause that effect. You must be right because it would be pointless to paint all the flooring under the carpet. warmonger
