Posts: 1,619 |
I have a 95 Mystique with the OBD1 in it. Will this make the 3.0L swap more difficult? Will I have to change anything to make up for the older diagnostics? I'm just beginning to research the 3.0L as I now have 140k on my car.
Thanks...
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile Moderator of the Florida Contour Enthusiast Group
Posts: 5,805 |
Chek PM's...you have mail!!
Posts: 1,619 |
Originally posted by Terry Haines: Chek PM's...you have mail!! Thanks for the info Terry.  Your PM was full so I couldn't write you back. Do you know if there is anybody out there who has done the swap on a 95? I am definitely interested in solving this problem. You can email me at rpaunovich@mediaone.net Ryan
Posts: 341 |
That is me as well. I hope to start getting parts for mine pretty soon. I am hoping to use an entire 3 liter engine.
Yankeyspeed: American power and ingenuity 95 SE -Stock enough Yeah my car has a baby seat, its still fast.
Posts: 39 |
I am with you yankee just use the whole thing good idea lets get together and figure it out.
1995 gl V-6 shaved trunk lowered 16" rims. custom one of a kind guages and i can get them if you like. dyed interior painted dash. ford 9mm plug wires. bat inlet tube. powdered coated intake. msd dis-4 ignition kkm air filter. honed polished intake. jet chip performance chip. Ricer wing.
Posts: 5,296 |
Come on, Terry! Why not make this public? Lots of anxious '95 owners itching to find the answer to this. Originally posted by Terry Haines: Chek PM's...you have mail!!
Posts: 1,003 |
Also very interested in hearing how OBD 1 can deal with the swap... Terry can you PM me with the info as well? Alex in Boulder, CO 95SE MTX 157hp 151tq before latest mods...
Posts: 341 |
Yeah we can do that. My plans right now are'99 or so entire engine.Then the mods to make it fit. The eletric water pump(of course) SVT fly wheel,SVT motor mounts, Grizzly clutch. The big plug wires from Ford. I am thinking I am going to have to chip it. If I have any money left I will go headers. One question, If I cant go with the aftermarket headers, Which manifolds should I go with,the 2.5 or the 3 liter?
Posts: 1,619 |
Originally posted by Yankeyspeed: Yeah we can do that. My plans right now are'99 or so entire engine.Then the mods to make it fit. The eletric water pump(of course) SVT fly wheel,SVT motor mounts, Grizzly clutch. The big plug wires from Ford. I am thinking I am going to have to chip it. If I have any money left I will go headers. One question, If I cant go with the aftermarket headers, Which manifolds should I go with,the 2.5 or the 3 liter? This is exactly what I'm planning on doing...but I want to use the 2.5 heads for a higher CR. I just figured out how much I'm getting back from the IRS.........lets just say I'm defininitely doing this, I want it done by Spring Zing!
Posts: 3,562 |
Originally posted by Yankeyspeed: Which manifolds should I go with,the 2.5 or the 3 liter? 2.5 manifolds, because the 3 liter ones won't fit. Headers will fit also without problem. The only real problem you'll face is the injectors issue. You either need to find a side feed 19-24pph unit, or (this way's easier IMHO) swap out some of the wiring harness, the fuel rails, and injectors from a newer return fuel system car. A customized ECU of some sort will also be needed (i.e. Superchips, Apexi, or some stand alone unit). OBD-I is actually easier to "fool" because it "knows" less about the car's functions. It also makes you rely on a little more tuning knowledge rather than a computer system to tell you what to do.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
