#403021 01/08/02 07:11 PM
SVTNupe Offline OP
I plan on ordering the 3L heads with the valves this week and I'm wondering now about the finger roller followers. First, I wonder if they even come with the new heads (question for Bill Jenkins) and if they do I understand that the valvetrain parts wear together but I plan to re use my SVT cams. I wondering if this will be an issue, using my old SVT cams with a brand new valvetrain.
Thanks.
Curtis
Dead 98 Black SVT
92K
#403022 01/09/02 12:43 PM
Heads do not come with followers or lifters.If the cams are good and the existing followers are good they can be swapped ,asume you numbered each follower & lifter with the cylinder/position when it was stripped......
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#403023 01/09/02 01:27 PM
SVTNupe Offline OP
Marked, bagged and tagged, Terry. What happens if you don't install the followers with the same lifters???
Curtis
Dead 98 Black SVT
92K
#403024 01/09/02 03:44 PM
All three parts 'wear together' & 'wear in' together, IF you did not number the parts and locations you could end up with rattles/taps/knocks. Its standard practice to mark all components on a teardown so the go back in the same place,unless they are being renewed......
V6 MTX
#403025 01/19/02 02:09 AM
so i take it that the 3L heads work w/the 3L swap and everything bolts together or am i missing something
~~~~~~~svt racing~~~~~~~~
10 sec. car in progress
