Terry or anyone else,
So can you take a Taurus 3.0L short block, and mate up to it a set of LS Heads?
If so, this is more than likely the way I would like to go, since I will be porting and polishing the heads and getting a set of custom cams made a well.
Also, when someone like me buys a set of heads from car-part.com does it come with all of the valve train components already installed? I would rather have them in there already and part of the cost, than having to buy all the little parts seperately.
Thanks,
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
