Originally posted by SVTNupe:
Okay, that's two for not changing the computer. Now can anyone tell me why??? It would be nice to know the answer before I start spinning my wheels.
I have found some wiring differences between the two PCMs but it's nothing that can't be rewired. So someone please tell me why I should run the 2.5 pcm vs 3L pcm.
Your 2.5L SVT ECU (I'm using thats what you have) has been optimized to give the best performace. The 3.0L is tuned for what? Family sedan and small suv. I don't think the programmers of the 3L had performance in mind, the 2.5L SVT ECU has a higher redline, it has a softer fuel cutoff point, has less frequent use of the A/C, difference cooling stragities, timing... blah blah I could go on
Now, comparing a non-svt 2.5L ECU to a 3L... you got me there, the only think I can think is that the 3L ECU might have a lower redline due to the engine being larger. Also the 3L ECU has been programmed for use with a ATX tranny, which I'm sure is programmed differently from a MTX (I'm still assuming you have a SVT)
