Posts: 539 |
hey man whats up. i know how ur feeling goin throught the same thing now. its almost like pulling on to a busy freeway...just close ur eyes and go, and u always make it. just be on these boards and ask n e question u have. i have compiled tons of info if u need me to fax to u something..
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 3,562 |
Originally posted by SVTNupe: Folks,
I'm not ready to give up yet. The tech manuals just aren't as detailed as I would have hoped. Hopefully, with the knowledge this group has, I'll be able to successfully swap my engine. I have no choice but to do it and I am quite a ways in to it. I have a couple of motor heads in my corner so I'm not completely alone in this project. Get one of the Ford CD ROMs... Todras has them for 8 bucks. I have one that I got about 2 years ago and it was great throughout the process. Anyone can follow the rebuild process as long as you know how to turn a wrench up to the point of making sure the cams are in the right place. One note... You can use a paint marker to make one mark on the crank area of the chain and gear and two marks on the cam end of the chain and gear for each bank of cylinders... that is IF the stock marks can't be seen that is. Degree wheel is the only way for sure to know, but heck, I'll bet the Ford mechanics don't even go that route. Any questions, PM me. I have a bare block I can take pictures of if you need me to point things out to you...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,050 |
Hi Terry, just a quick question. Don't you have a solution to 'beefing' up the mtx 75 trans while still keeping the shifting mechanism stock? If so, how much? warmonger Originally posted by Terry Haines: I/We,HMS Inc,have offered seminars on *MTX75 Trans*Duratec Engine*Zetec Engine*Suspension,Brakes & Steering* as our only two students on the MTX can testify,they now know how to strip an MTX and install a Quaife,the same can be said of a Duratec..We will also fit your Quaife if you are interesed in shipping the trans...PM me ,Regards Terry Haines,HMS Inc
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 5,805 |
Yes we do.Its called the 'Bulldog Box' & is an upgraded MTX75 re syncros,shifters etc,has a pressure feed lube system ,lube heating /cooling system,comes with Quaife or Torsen LSD fitted,is built from a NEW MTX75,they are $2500 exchange.Regards Terry Haines,HMS Inc
Posts: 1,050 |
Originally posted by Terry Haines: Yes we do.Its called the 'Bulldog Box' & is an upgraded MTX75 re syncros,shifters etc,has a pressure feed lube system ,lube heating /cooling system,comes with Quaife or Torsen LSD fitted,is built from a NEW MTX75,they are $2500 exchange.Regards Terry Haines,HMS Inc Thanks for the info, sounds like a great package, but I'll be waiting till next spring tax time to fork over that much cash in one shot. warmonger
