#402437 11/09/01 03:33 PM
has anyone tried to put a 3L crank and rods or just crank in a svt engine. i have a svt engine in my garage and i have time to fool around with it does anyone think that this could work. any info would be helpful. and yes i did search and all i got was sho shop 3L conversion.thanx smile
modded? maybe. wanna race?
"if i think with my d!ck then put your mouth on my brain"
#402438 11/09/01 04:48 PM
3L Duratech is a BORED 2.5 if you want to look at it that way. Exact same stroke at the 2.5.
#402439 11/09/01 08:10 PM
Administrator
Administrator
Just to clarify, the crank and rods are pretty much the same (prolly identical) between the 2.5L and the 3L, the big difference is in the cylinder bore.
It's all about balance.
bcphillips@peoplepc.com
#402440 11/11/01 04:39 AM
thanx for the info guys.
#402441 11/12/01 03:31 PM
so why not just swap the crankshaft during the process? that way no "grinding" is needed to fit the mtx.
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
#402442 11/12/01 04:20 PM
It would take a lot more work than grinding and would give the same results. But if you completely tore the engine down putting in the other crank may not be a half bad idea.
Ryan
Latest Mod: Mirko Splitter
