Posts: 1,682 |
Will the 3L upper/lower intake manifolds bolt up to the SVT heads?
Administrator
Administrator
Posts: 702 |
The lower will work with modifications (the IMRC linkage is different), but doesn't the upper have the throttle body on the opposite side?
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 5,805 |
Nope,Taurus is on the same side but not sure of the 'package' clearence under the hood.
Posts: 3,562 |
Originally posted by bret: Will the 3L upper/lower intake manifolds bolt up to the SVT heads? Not as factory pieces, no. The 3 liter lower must be modified if you want it to work with the 2.5 upper, or leave the 3 liter lower stock and modify the EGR and vacuum lines to work on the 3 liter upper. Not a direct swap. There may be some clearance issues with the hood as well with the 3 liter upper, but by my mearurements, it "SHOULD" fit. One benefit of the 3 liter upper would be convensional porting is possible because of the straighter flow paths... I have an extra one if you want to work a deal on it...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,682 |
i think the 01 builds have it on the same side as the contour... correct me if i am wrong...
Posts: 3,562 |
Heheheheh, hot topic I guess. 4 responses in less than 5 minutes...  I have two uppers with the TB on the same side as 2.5. Slightly different angle too. Add to the mods list to make it possible, custom throttle/cruise cables.
Posts: 1,682 |
i am not talking about fitting one or the other, but both...
Posts: 3,562 |
Originally posted by bret: i am not talking about fitting one or the other, but both... Find an upper first. Cheaper. The lowers have the same height and mounting points, so any measurements should be the same. :EDIT: The TB being on the same side on my manifolds are one '98 and one '99.
Posts: 3,248 |
Bret, the 99 SVTs have the (modified)3L lower already (I think). My lower is 35mm, same as David Z measured for his 3L lower (his E0 lower was only 32mm). Also, I had a conversation with an SVE engineer who said something to the effect of "they changed to the 3L lower" on SVT engines but did not give a date - so it may be that E1s have it as well. Interestingly, several Cougar guys have reported a 35mm lower but I think Brad Noon had a 32mm on his 99SE. Go figure.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 3,562 |
I have yet to find a return type fuel system with the larger lower intake. I'm thinking that it goes together with the fuel system switch over... Just a thought... BTW, my '99 SE is return type.
