Ok, I'm having problems getting this to format correctly, so I'll explain it. This first pair of numbers is for the 3L and the second pair of #'s is for the 2.5L In each pair, the first number is the metric spec (most are mm) and the 2nd #, the one in ( ) is english, most are inches.
If anyone needs a better layout of the #'s, email me. (I threw a few other measurements in for fun
Data is based on the 1999 SVT Contour 2.5L and the 2001 Taurus 3L
3L 2.5L
Bore mm(in) 89.0(3.5) 82.4(3.24)
Stroke 79.5(3.13) 79.5(3.13)
Bore Spacing (C/L to C/L) 102.0(4.02) 102.0(4.02)
Block Deck height 208(8.19) 208(8.19)
Block Length 396(15.6) 396(15.6)
Deck Clearance (minimum) 0.415(0.016) Below to 0.115(0.0045) Above
Cyl Head vol. (above gasket) cm3(in3) 48.2(2.94) 44.5(2.72)
Hd. Gasket thickness (compressed) 1.00(0.040) 1(0.034)
Min comb. Chamber vol (total) cm3(in3) 52.0(3.17) 45.1(2.76)
Valves Intake 35(1.38) 32(1.26)
Exhaust 30(1.18) 26(1.02)
