#402246 11/07/01 03:49 PM
jiako Offline OP
I was just reading Dave Z's 3L swap info and i was wondering since i am goin to be using the 3.0 heads with svt cams which fuel system should i use. Also if anyone has any other info on which parts to use off the 3.0 and which to keep from the svt please chime in. Thank you
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
#402247 11/08/01 03:21 PM
You should use the SVT lower intake on the 3.0 since you wouldn't want to swap over to the returnless system. If you swapped to returnless no S/C or NOS. Just so you know.
Lee Cox
In life begins responsability...
Project Car
#402248 11/08/01 04:07 PM
jiako Offline OP
oooohhh....so if you swap lowers u need to swap fuel systems....why is that. Just wondering I am a novice. I guess that means more porting.
#402249 11/08/01 04:16 PM
The lower intake is what has the fuel rails and the injectors on it and connect to the fuel lines. On the 2001 3.0 Taurus the lower intake is returnless. You have a Return style since your car isn't a 2000.(that's when they changed) If you were to change to returnless you'd have to swap the fuel lines, gas tank, fuel pump, and PCM out of a 2000 SVT. No small task and to think i have to do this...
Lee Cox
Project Car
#402250 11/08/01 04:21 PM
jiako Offline OP
F' that.....I rather have the return type n e way.....I do see forced induction in my future......and some of that funny gas too. Think i would break 12s with that setup.
#402251 11/09/01 09:21 PM
The fuel rails will swap between lower intake manifolds, it wouldn't be prudent to swap from returnless or vice versa anyway because you'd have to change fuel tanks, lines, ECU's, FPR's. etc... just wouldn't be worth it... The 3 liter lower is about 1mm larger than the SVt unit, but the secondary actuators must be modified to work with the 2.5 uppers...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#402252 11/09/01 09:46 PM
But...if you use the LS 3.0 ok its returnless,but its closer to the Jag V6 (NO finger followers on the cam,direct acting buckets etc etc...)and more HP at 'stoc' level! wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
