Page 3 of 3 1 2 3
my tires spin spin n spin some more....no way it activated in my 99svt but it could just need a normally closed switch to make this work....
just curious but what would be the benefites of having this option....
pauli18@aol.com for questions
99 green svt
asp udp
b-n-m short throw
kkm intake
n the list grows steadily
Y
Y
Originally posted by Chris Hightower:
And, those people that do have the wiring, are you [b]sure TC isn't kicking in without you knowing it? Peeling out on wet pavement would prove something.
[/b]
Believe me , if the TC is kicking in , you'll KNOW it . There's no doubt about it ... throttle pedal jumping around , buzzing & clicking , light flashing & away you go . No tire spinning . You'd have to be in a coma not to notice it :p ! I LOVED the traction control on my '95 SE & I wish that my SVT had it frown . That's one major thing I miss from my SE (apart from the quality control issues of my '00) .
BTW - the button is there to defeat the traction control , not enable it .
~~~~~~~~~~~~~~~Allen
********** Love Those REDWINGS !!! **********
2000 Contour SVT Black w/ Tan #2137 of 2150 / built 2-4-00
Mods : ~ Factory DRL mod ~ "Powered by Ford" seatbelt covers
~ OF's TH fix ~ Audi A-6 Side Repeaters ~ Highs in Lows Mod
~ #885 foggies ~ KKM filter ~ Mondeo ST200 Badging & Shiftknob
~ Pre-98 Sails ~ Nose Bra ~ Trunk cargo net ~ '98 Clock
~ "Glasspacked" Resonator ~ Painted Rear Reflector
~ Räzo Pedals ~ Custom "Mondeo" Windscreen Banner ~ Ventvisors
~ Lighted Moonroof Switch ~ Mystique Rear Seat Light
~ Painted Grille Ring ~ H&R Springs & Mondeo ST200 Struts
~ Mille Miglia "Cello" Wheels
My old 95 \'Tour SE ~ New SVT pics here
Hey guys.. umm I may have an answer here.. of sorts.. for the right question..
My question in the post is a bit different though.
My post
I think they changed the ABS module and it came with TC.. one obvious thing is that the TC light comes on now on the dash. It never did before.
How do I get the switch?? what's the part number.. as you can see, I obviously need it.
Dave Andrews
Black&Tan 2000 SVT 225 of 2150
Bassani.. UNCORKED
davelandrews@comcast.net
"Nothing is so firmly believed as what we least know." -Montaigne
T/C equipped should have something different on the TB too, right? Elizabeth (IIRC) had rigged up T/C on an SVT.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
My post
Hey Dave, I just ordered the switch and from your information it appears I would need the newer ABS module for this traction control to work. I paid $25 - $27 for the switch and if you want I would sell it to you for $20 shipped. I know it is only a $5 - $7 difference but every little bit counts, right??
2000 Contour 2.5L ATX (Medium Steel Blue)
Items for Sale
  • SVT Indiglo Guages (NEW)
  • Traction Control/Rear Defrost Switch (NEW)
  • V6 Speedometer/Guage Cluster w/ Tach (51k miles)
Sure thing.. email me..
check my sig it's there.
We'll need to work out details.. payment..shipping etc..
Dave Andrews
Bassani.. UNCORKED
Guys...traction control is more than just a switch. looking at my old zetec ATX, the throttle cable comes up the firewall, over to the passenger side of the engine, and behind the headlamp it goes into a "motor" which then has another cable coming out of it and going to the TB. I'm assuming this thing is in the same place on a v6 tour, but anyway..what this does is basically sense the wheels are slipping and lowers the amount of throttle to the engine by itself. I actually had this go bad on me and wound up not able to drive the car. THe fix was running the throttle cable directly into the TB...of course resulting in a permanent TC light. But anyway, it is a physical motor as far as I know....Doesn't interrupt spark unless they changed it on late model contours. and not to sound rude, but who cares?! It's a useless feature. Trust me it does not help snow driving. I've had less trouble with my SVT in the snow than my old car...Dave your pboblem is weird...sounds like TC and at the same time doesn't...I hope you get it solved quick though. And give me all the details!
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
The 98 and newer traction control is very different. It does not close the throttle to cut power. It cuts power thru the PCM as well as gently moderating the brakes at the individual wheel or wheels that it wants to control. On this type of a system, the Traction Control is mostly an inhancment of ABS. It seems that the whole idea of this thread is that perhaps the SVT (or maybe other ABS equipped 98 and newer cars as well) already have most of the Traction Control built in and just may need something minor to finish the availability of it.
Jim Johnson
98 SVT
I'm tired right now..
I've got the full story about this now.. and well you may or may not like what you hear about it.
I'll post in the next day or so. I will say that TC is possible, I don't recomend it. You'll see why.
Dave Andrews
Bassani.. UNCORKED
Go here on this.
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic;f=2;t=003628
Dave Andrews
Bassani.. UNCORKED
Page 3 of 3 1 2 3
