Page 2 of 3 1 2 3
Administrator
Administrator
Originally posted by F111D F:
Have to have ABS first?
Paul
Yes. That's how traction control works. PCM
senses front wheel(s) slipping and cuts out the ignition until it gets grip again. That's what it does on my LS anyway along with applying brake to the wheel(s) that slip.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
I noticed that on my car a year a go. I thought that it was for a heated windscreen since thats where the switch is located on the Mondeo.
As far as the TC not working I think the switch has to be plugged in. since it isnt there is no completed circuit so it would'nt work. Maybe the bulb is pulled from the socket too. Someone who has pulled/pilling there dash could verify.
Would be nice to have if all we need is the swicth. Has anyone checked the fuses and relays if any for the TC? are they in place or pulled?
I looked in the manual for the TC fuses but there aren't any, probably intergrated into the ABS fuses and relays.
any thoughts?
"It's the little things that count" The Wedding Singer
svt24v@yahoo.com
ICQ: 3699352 (Contour.org for auth)
00 SVT #555 of 2150
Built 11/24/99
Bought 12/23/99
T-Red/Tan
KKM
No Resonator
Amber Cougar Side Markers
Cougar/Focus Antenna
Heated Drivers Seat
Heated Mirrors
My 95 has TC and boy does it suck. I hate ABS too, on wet pavement with SVT rims and plenty of tread left on the kdw's ABS kicks in and makes driving (rather stopping) interesting. They need a off switch for ABS like they do for the TC.
The TC is fun sometimes and helpful once awhile in the snow, other than that, you guys can have mine
My 2000 SE also has the wiring. If somebody goes out and gets a switch and it works I would like to do the same.
2000 Contour 2.5L ATX (Medium Steel Blue)
Items for Sale
  • SVT Indiglo Guages (NEW)
  • Traction Control/Rear Defrost Switch (NEW)
  • V6 Speedometer/Guage Cluster w/ Tach (51k miles)
I have that traction control switch thingy too....
-Mancho- cars name is Connie
99 Silver Frost SVT #1986
k&n filter with cut out box
true duals w/ flows smile
Ground Controls with 17's mille miglia ...
Hightower headlights
15.4 at 90.29 at Milan dragway before the true duals smile
do we have an answer yet???
svt24v@yahoo.com
00 SVT #555 of 2150
Built 11/24/99
Bought 12/23/99
T-Red/Tan
KKM
No Resonator
Heated Drivers Seat
Heated Mirrors
Just to clarify one point, my SVT did not have the switch, intially, but the TC light and TC itself was fully functional. The switch is only there to disable the TC. You have to turn on the light on the TC switch, by depressing the switch, to disable the TC.
Administrator
Administrator
No switch to install yet here in Dallas on Chris_SVT's car. However, can one of you that do have the wiring check to see if you have a light bulb in place? Also, I'm curious as to what other hardware is needed to make the T/C kick in, if anything.
And, those people that do have the wiring, are you sure TC isn't kicking in without you knowing it? Peeling out on wet pavement would prove something.
Worst case scenario, you would need the programming in the PCM to get it to work. Or is there another computer for ABS/TC. I dunno, I have a silly GL without any of that fun stuff!! :p
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Originally posted by cawong11:
[b]As far as the TC not working I think the switch has to be plugged in. since it isnt there is no completed circuit so it would'nt work. Maybe the bulb is pulled from the socket too. Someone who has pulled/pilling there dash could verify.
Just to clarify one point, my SVT did not have the switch, intially, but the TC light and TC itself was fully functional. The switch is only there to disable the TC. You have to turn on the light on the TC switch, by depressing the switch, to disable the TC.[/b]
Oh, well s, I just special ordered the switch for $25 for mine. My car has the wiring but does not light up when I turn on the car. Also, my car likes to spin out whenever it is wet out laugh I guess I'm just always pressing that gas pedal too hard :rolleyes:
Sooo, I guess this means that the TC on my car doesn't work. I'm going to try the switch anyway's but if it doesn't work I guess I'll just sell it to someone who wants one for $15 with shipping paid by me.
Items for Sale
I'd probably take the switch but I'm in Canada. I'm getting ready to replace my dash bezel with a 98 or newer one but can't find the switch.
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Page 2 of 3 1 2 3
