NO prob bigwalton, I see what you are saying cause I was kinda saying what i didnt wanna say to, and i see where i am wrong......
the A/C will force your fan to run high, meaning it will keep the engine bay cooler, making the engine run cooler, however, it does put a load on the engine as you said above.
I was not really thinking about the problem when I said some advice!! my fault!! I saw the overheating, and forgot all about the water pump goin, so that is my fault for not being as detailed as i usually am!! sorry for the mistake, but yes bigwalton is correct if you can stand using the heater then use it, but do drive conservatively and rarely!! if you cant, do not drive her at all!!! take her to get fixed asap, or else you will be purchasing yourself a new engine
HOWEVER, if it does go, what a good opportunity to get yourself a SVT engine!!!
