Administrator
Administrator
Posts: 5,037 |
Originally posted by Tim O.: Kudos Chris, very good numbers indeed!
Any idea how well that TC would run on a 3.0L?
Tim '00 SVT With low compression (8.5:1 or less) and beefy rods, the sky is the limit. Just don't tell your tranny :p
Posts: 651 |
VERY impressive numbers Chris! Will we be seeing any 1/4 mile times in the near future? -neal
99 SVT...modified 96 GL....the beater "I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
Posts: 1,108 |
Kick Ass don't Kiss It
Posts: 349 |
Because of this post I have decided to ignore all turbo related posts....j/k.
You are really making me want to go into serious debt right now.
BTW...My engine has 70,xxx km's on it right now, and will probably have more on it by the time I can afford this kit and all of the upgrades that should accompany it. What kind of things should I do to freshen-up my engine before I hammer 290fwhp to the ground?
Evan Groenke 1999 Silver Frost SVT #1919 183.9hp 163.7lb/ft tq @ the wheels Now bitter at Ford
Posts: 1,050 |
OMG, its beautiful Chris!
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 1,202 |
Gees Chris. Maybe I should have waited for your turbo kit. Excellent numbers.
Posts: 1,050 |
Originally posted by DemonSVT: Ummm...
Wow...
That's a very linear powerband!
The secondaries are definitely not needed and a restriction. Actually, I think it would still be better to keep them so that the initial take-off before the turbo spools is better. However, I'm sure that turbo is spooled by the time the engine is hitting 2 grand, therefore opening them much earlier would be smart. I am guessing that opening the imrc around 1800 rpm would be pretty beneficial when the throttle postion is WOT. For good fuel economy you would want to keep its normal opening procedures when not at WOT. warmonger
Administrator
Administrator
Posts: 5,037 |
The secondaries are needed down low or you bog. If the intake manifold was like on the ST220 or even the Taurus, the swirl/tumble effects would allow for no secondaries and still have good low RPM performance. As you can see around 3500RPM there is not a HUGE jump, but rather a smooth curve. This means the secondaries might need to be opened just a little sooner, but still needed due to the runner config. Oh, and we just went a little higher today with 93-ish octane gas. Returnless fuel systems are pretty cool once you figure out how to play with them.
Posts: 3,066 |
Originally posted by 69Boss302: Umm, I'll be in the bathroom if you need me
I'll be there too!! Only a different bathroom =)
STD's are like Pokemon... Gotta catch em' all!
Posts: 3,421 |
I would love to see some Vids chris.
