Posts: 183 |
I've had my car to the track twice now and I'm confused. My launch is terrible(60'= 2.45- 3.57) and for some reason my trap speed is always 86mph. Even on my 17.22  I trapped 86. 16 flat, I trapped 86. 15.7, I trapped 86. Is my car falling on its face after the shift to fourth gear? Am I doing something wrong? I'm lost. -R-
2000 SVT Contour Tropic Green Flavor Born 1/7/00 #1346 of 2150 This is one drag queen not defined by time slips
2002 Acura 3.2TL Type-S Aegean Blue Pearl If only it were a 6-speed
Posts: 153 |
Originally posted by Green Jelly Bean 2000: I've had my car to the track twice now and I'm confused. My launch is terrible(60'= 2.45- 3.57) and for some reason my trap speed is always 86mph. Even on my 17.22 I trapped 86. 16 flat, I trapped 86. 15.7, I trapped 86. Is my car falling on its face after the shift to fourth gear? Am I doing something wrong? I'm lost.
-R-Hmmm, must be a Contour thing. My one trip to the track netted a best of 16.0 at 86.7 mph. Like you, I had horrendous launches. I haven't been back since doing most of my mods and figuring out how to drive better (I hope) so don't know what the car'll do today. Don't know the physics of why different times would give the same trap speeds though?
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
Posts: 3,419 |
Think of it using these hypothetical examples:
Good launch, you get full traction at 10' and go full power and traction for 1310 feet.
Bad launch, you get full traction at 50' and go full power and traction for 1270 feet.
Think those 40' are going to make much difference in the speed you reach at the end of the track? Not really, just a slight difference. But, it will take you significantly longer to go the full 1320 feet with the worse launch (mostly because it took you longer to get through the first 60').
Posts: 2,848 |
And let's not forget THESE ARE NOT DRAG CARS!!!!
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 316 |
Yes they are, they DRAG right down the track.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 153 |
Think those 40' are going to make much difference in the speed you reach at the end of the track? Not really, just a slight difference. But, it will take you significantly longer to go the full 1320 feet with the worse launch (mostly because it took you longer to get through the first 60'). Ahhh, of course - and I have a degree in mech e :rolleyes:
Posts: 3,419 |
Perfect, so that example is right up your alley (Mfg E degree here).
Posts: 153 |
Originally posted by PA 3L SVT: Perfect, so that example is right up your alley (Mfg E degree here). Yeah - but I haven't used mine for about 4 years.... (I figured out I could make about 40% more money designing SW. Now instead of desiging mechanical prototypes and analysing reliabilty I design multi threaded distrubuted applications while sitting on my @ss in front of an SGI terminal all day)
Posts: 613 |
dont seem to have that problem, I hit almost 92 the other day in the quarter ?
~~~~~~~~TRAVIS~~~~~~~~ Now driving: I MEAN NOT DRIVING---- 1995 Contour SE Maroon, MTX, sunroof w/rain-guard, neons, and audio replaced. Side Markers installed and headlight strobes also now on. *KKM tru-rev - I love it 9mm FMS blue wires SVT Upper SVT exhaust SUPERCHIP˛ custom ram air Newest mod = f***ed up engine, prolly shot, yeah
Posts: 1,447 |
If it makes you feel better I have good launches and still only get 87-88mph trap, best 60ft is a 2.26 and I have several other 2.2x's all with respectable RT's . Not sure what the deal is, and no I dont lift my foot in between shifts and I barely release the clutch. Could be the track your on, I know for a fact the track i did these runs at is a good .2 slower than Norwalk (in Ohio) Hopefully I'll get out there and lower my ET to what it should be.
