Posts: 422 |
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 142 |
Dan,
How much did the dealership charge to install your DMD? I'm just itching to get mine done too. I may also have the preemptively install a metal water pump.
Thanks,
George
George Hodge 2000 SVT Silver Frost 1188/2150 DMD HPP Rear strut tower bar SP Motorsports "22mm" sway bar BAT European Handling Kit
Posts: 3,248 |
ghodge, it was 1.5 hrs at around $65 hr - about $110 w tax. Did not have the tools nor inclination to do it myself (crankshaft seals & all).
FYI, also had them throw a new accessory belt ($36) on even though I have only 24.5K on the car. Belt looked fine but my wifes 3.0L Duratec Sable had belt replaced after some modest wear changes caused it to fail state inspection at about 50K miles. The install labor costs more than the belt and they can replace the belt for no extra labor if you are doing the damper.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 3,584 |
Thanks for the info guys but you said the dealership installed it? I thought this was some kind of an "aftermarket" item, why would they install such a thing  If I get around to doing this I'm going to THM, period
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 142 |
Dan,
Thanks for the installation price info and the tip about the accessory belt. Roger, the DMD is a Ford part so they shouldn't have too many problems with installing it.
George
Posts: 3,248 |
"I thought this was some kind of an "aftermarket" item"
Nope, it's the redesigned Ford OEM harmonic damper(was "single mode" now "dual mode" which reduces crank bending and presumably crank whip) used on current 2nd generation 2.5L Duratecs in the Euro Mondeo. Ford PN and everything. I told them it was a geniune upgraded Ford part, they said OK.
Posts: 656 |
Finally got mind installed at a transmission shop managed by my cousin. With the money I saved vs the dealer, got a new Craftsman click torque wrench and puller. How's $35 for labor and new Autozone/Kellyspringfield belt. I helped and learned something ( hopefully won't have to do that again.) :rolleyes: Paul I helps to an YORF! 98 Mystique LS built 7/97 on yes it takes poly-v for a 97. The 98 uses a belt approx 6" longer? Must be a different tensioner???
I just love having this inside info ( past experience in military & phone company it's amazing all the corruption and greed out there) , now to slowly work on Ford for a parital refund. One way or the other. And as always with inside info, the source needs to be protected! "Terry thanks again for procuring the part" I can assume Ford US will never volunteer to or admit to??
Posts: 103 |
Posts: 1,507 |
Originally posted by Alex MacLaurin: Whats the Ford part#? You can only get it overseas.....actually you won't get it so call Terry  Seriously, everyone is just getting them from Terry @ HMS. Look Here
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 463 |
Hey Dan, did you order your DMD from Terry and then had the dealership install it or did the dealer actually got a hold of the part for you? Then what's the Ford part #? Thanks.
