Posts: 5,805 |
Phat SVT, Where are you comming from...'not ment to have boost'..rubbish...the timing was the only issue and FWIW we build up motors weekly that 'light' with the first turn of the key...
Posts: 3,562 |
Certainly didn't expect it to go to total failure on it this soon. Like I say, I can't tell you what anyone there did to prepare for the first dyno run or even if the motor was hurt before he got there. All I know is what "should" have happened. If they truely did try to do a full throttle run without any ignition retard, then some fault spreads on each of us involved for not making sure everyone knew what needed to be done to pull out the timing before the foot went to the floor. I *knew* something was going to need to be done for a full throttle launch, the dyno guy may have thought a chip was already in there, MSD was in/out... what ever... To many variables right now to know for sure what went down at the dyno or on the way there. All I know for sure right now is that I'm heart broken and so is one of my friends.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 5,805 |
Brad, det is an engine killer at s/c,t/c or nat asp, it only takes microseconds to kill a good motor....
Administrator
Administrator
Posts: 4,527 |
my condolences go out to Rick and what is left of the beast.
I honestly believe the failure was due to a lack of proper tune (duh) and just a little too much impatience.
Rick, let me know if I can help out in getting things back together.
It's all about balance.
bcphillips@peoplepc.com
Posts: 3,419 |
Posts: 176 |
I hope Rick is allright. Brad give me a call this weekend if you want me down there for a teardown, or if we need to take Rick to the bars for therapy. I'm bachn' it all weekend and I'll be in the car and down there in 1 hour 45 if need be Please let me know whats happing
2000 Roush Cougar MTX MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
Posts: 2,848 |
Rick...I feel for you man...
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 955 |
nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
(breathe)
(breathe)
Dammit rick, i really wanted to see those numbers, i was with u all the way, so sad it ended like that. Well on the bright side, u still have the svt block, so u can always revert bak to that.
Experience is the worst teacher; it gives the test before presenting the lesson. "You peel my onion down to the nun" - Gene Hackman [Under Suspicion] -Walter- 96 Contour LX
Posts: 1,611 |
Man guys, you got me all misty and weepy with the emotions going on here. It was a sad day indeed. I got home about 10PM our time and hope to have a diagnosis tomorrow once I get the engine pulled (ugh) and pop the head off. Truth of the matter is the car had been running so well I didn't even think of the timing issue and since the owner of Cerra's wasn't there no one there really thought of it either. SZ is really up in the air right now. Both for me and the car. I'm assuming the wife will have some input on this whole situation so I'll be waiting to see what that is. Wish me luck and I pray it's only a head gasket but I'm prepared for it to be 1-3 pistons needing replaced BTW, numbers she put down were 241 HP and 231 Tq at 5700 RPMs before it leaned out on me. That is dynoed in 4th gear.
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
