Posts: 2,708 |
The one in the older pic was his 98 uim, the one in the current pics is the 2000 uim which has been beed blasted.
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 3,562 |
Originally posted by WorldTour: The one in the older pic was his 98 uim, the one in the current pics is the 2000 uim which has been beed blasted. True. Also added on was a 65mm TB... Mark, no argument started. The chip wouldn't work with this set up because we were removing the FMU, going with the 42# injectors, as well as the code was different and trying to tune one over the phone was out of the question. The reason our set up didn't work was because of the MSD box not working as promised and Rick taking the chance that it was safe to drive gingerly to the dyno to get a new program on his chip. Unless his right foot got a little carried away on the way there, she should have been fine. Perhaps he forgot about the spark issues for a moment or something... What we wanted was a chip for the track, then use the MSD to back timing out further for the street. Race gas would have been sweet as would a little bit of water/alcohol with an aftercooler. Still lots more that could be done to a Contour... Someone said it... Chalk it up to pioneering different ideas...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 3,598 |
Originally posted by bnoon: Checking custom pistons availability now...
JE Pistons: 714-898-9763 Originally posted by bnoon: Someone said it... Chalk it up to pioneering different ideas... Well said. You can't make an omlet without breaking a few eggs.... Too bad these eggs are so damn expensive...
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 1,428 |
At least the rear bumper isn't sagging on Rick's car..  Okay, I'll go away now.. :rolleyes:
Posts: 1,071 |
 You guys will get it back on track. Thats a real bummer, I was really looking frward to those #'s. Making me have second thoughts about my big injector custom chip plan. Good luck
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 1,296 |
So Rick did not have the chip in then? When I had the S/C I was getting ready for a show and I had everything installed and was waiting for the chip to arrive VIA fedex. It never shows so I called Vortech and they said I could drive the car without the chip as long as I kept it under 4,000 rpms. If I were to go over I would have put a few holds in the pistons, at least that is what they told me. So I was just wondering if not having the chip in could be the reason for this?
Either way, my heart goes out to Rick. He put so much time and effort in that car. I hope everything works out.
Tim
Posts: 3,562 |
Thanks for the edit Steve, but certain people who work for certain companies have better prices and are looking to help us out. Yes, Tim, you stated one of the reasons it should have stayed below 4-5K. After that RPM boost starts to build and with stock ignition advance in place detonation would start. Most likely what happened here. I sure hope they made the dyno run with some kind of chip in place and didn't run it without anything in there!!!
Posts: 1,296 |
Originally posted by bnoon: Thanks for the edit Steve, but certain people who work for certain companies have better prices and are looking to help us out. Venolia Pistons http://www.venolia.com These are the same people that Rick called about the rods when they sent him to Cunningham.
Tim
Posts: 3,562 |
Originally posted by [Corbett]: [QBVenolia Pistons http://www.venolia.com These are the same people that Rick called about the rods when they sent him to Cunningham.[/QB] Thanks Tim. IIRC there was a connection to someone there too, cough...
Posts: 1,296 |
Originally posted by bnoon: I sure hope they made the dyno run with some kind of chip in place and didn't run it without anything in there!!! Well if they didnt it would explain what happened. I know brad wasnt sure if my ecu and his were the same codes so he may not have run the chip at all. Let me know.
Tim
