Made about 9 runs total...
First run, S-AFC settings set to 0% correction.
170.0hp (no TQ #s on this run, forgot to hook up the RPM signal wire)
Added fuel w/ the S-AFC, ended up w/ 6% from 0-4k rpm, and 4% from 4k-7k to get the best #s.
172.9hp 155.1tq'Only' 2.9hp peak and about 3 lb/ft of peak tq increase w/ the S-AFC, BUT looking at the graph; 2k-3700rpm the increase is about 2hp, but from 3700-6500rpm, I'm averaging about
6-8 more hp w/ the S-AFC. Nice, very nice. Peak isn't all that great, but mid-range is awesome.
Decided to pop in the chip just for ****s and giggles, (pinged like a mofo last time) and got...
173.8hp and 153.8tq (in combo w/ the S-AFC)
Good news, no more detonation w/ the chip, but I'm loosing about 6-8hp from 1-3700rpm, and about 2hp rest of the way, until I peak at a 1hp increase over the no-chip run. Torque has even worse losses.
So, only time I'll be using the chip is at the strip where the higher redline helps tremendously.
Wideband O2 was being used for all the runs, ended up w/ a 12.9-13.2:1 ratio.
I had previously used the O2 voltage readings to tune the AFC (duh), but holy shiz are they inaccurate. Before the dyno, I had added anywhere from 20%-26% more fuel. Way too damn rich, even though O2 voltage was about .91-.92 in 4th.
Having 83k miles on the original O2s has something to do with it of course, but still...
Anybody w/ a AFC, get it DYNO TUNED!!!!
In the end, peak gains are decent (3hp) but midrange is very impressive, w/ the increases peaking at 8hp at the wheels.
Phew, sorry for the long post, but it's been a pretty damn good day. Simon's numbers are very impressive, and w/ a few adjustments, 280fwhp isn't unrealistic.
Mods at the time of dyno-
KKM intake
Magnecores
Bosch plugs
SMA Y-pipe that leaks
FST4DR cat-back that ain't exactly 'flow friendly'
S-AFC
SS pulleys
Got my best run with only about a 5 min cooldown after doing 6 runs, with a longer cool down time, I think the HP numbers could have been a tad higher. But who cares.
John
