Page 2 of 3 1 2 3
#397289 03/21/02 08:30 PM
jiako Offline OP
thank you...just picked them up...and mite buy me some new wheels too
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
#397290 03/21/02 10:17 PM
Be careful. Our stock Differential / Tranny / Clutch was not made to handle that type of traction. I had a friend (type of car to remain nameless)that blew his half shafts with a clutch side-step on 555r's.
Po-Jay
Ghetto Mods Galore!
Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap-
Blood,Sweat,Tears
Do I hear the Fat Lady singing?
98 E0 Silver Frost (Is there any other color?)
172HP 149TQ W/Bad A/F Mix
#397291 03/21/02 10:42 PM
F
F
I've got a quaife and driveshaft shop axles wink my diff bit the dust a long time ago laugh Still got the stock clutch, so that'll be the next thing to go :rolleyes:
But I agree, be very careful with stock drivetrain with drag radials.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
#397292 03/22/02 08:01 PM
jiako Offline OP
I have a quaife now and and installing a Ram super duty 6 puck full metallic clutch. So now i just have to wait for the drive shafts to go.
#397293 03/22/02 08:21 PM
How much (and how difficult) were the drive shafts???
Po-Jay
Ghetto Mods Galore!
Blood,Sweat,Tears
#397294 03/22/02 09:53 PM
Drive shafts aren't difficult to do, just expensive. Stage II's IIRC are around $500 for the pair. Stage III's (like mine) are around $900.
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#397295 03/22/02 10:31 PM
THe Nitto's are down to 60 dollars at discount tire!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#397296 03/23/02 11:39 PM
Originally posted by CB99SVT:
I run mine at 32-35 psi and have a best of 2.04 60' time. There isn't any advantage to running lower pressure as the tires aren't designed to be run that way.
Okay, I guess all the mustang guys who run their radials at 15-18 psi don`t know what they are doing? I run about 20 psi in mine at the track.
14.72@ 92.6 mph
www.modularV8.com
"CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
#397297 03/24/02 07:11 AM
Originally posted by svt2000:
[b]I run mine at 32-35 psi and have a best of 2.04 60' time. There isn't any advantage to running lower pressure as the tires aren't designed to be run that way.
Okay, I guess all the mustang guys who run their radials at 15-18 psi don`t know what they are doing? I run about 20 psi in mine at the track.[/b]
RWD vs FWD.
No weight transfer to the tires with FWD.
There is a major difference right there.
2000 SVT #674 - Check it out!
#397298 03/24/02 06:42 PM
well.. considering you drive a contour... i would listen to what the "contour guys" have to say... not the "mustang guys". a mustang is a 2door rwd coupe, alot of mustang guys see good results running 3.73 rear end gears... that doesn't mean a contour would...
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
Page 2 of 3 1 2 3
Moderated by  mbb41_dup1
