Posts: 539 |
Which ones do you guys have? where did you get them? Does anyone have a set they don't want for 16"? will pay of course
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 999 |
Originally posted by jiako: Which ones do you guys have? where did you get them? Does anyone have a set they don't want for 16"? will pay of course I have the Nitto`s 555R. Got them from Discount Tire for 110 a piece.
14.72@ 92.6 mph www.modularV8.com "CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
Posts: 539 |
thanks man...not a bad price
Posts: 1,447 |
Originally posted by svt2000: Originally posted by jiako: [b]Which ones do you guys have? where did you get them? Does anyone have a set they don't want for 16"? will pay of course I have the Nitto`s 555R. Got them from Discount Tire for 110 a piece.[/b]Did you ever check on the size? TIA
Posts: 999 |
Originally posted by KnuKonceptz: Originally posted by svt2000: [b] Originally posted by jiako: [b]Which ones do you guys have? where did you get them? Does anyone have a set they don't want for 16"? will pay of course I have the Nitto`s 555R. Got them from Discount Tire for 110 a piece.[/b] Did you ever check on the size?
TIA[/b]225 50R16 is the size of my tires. Sorry about the delay.
Posts: 16 |
What psi do run them at on the track?
JAKE OUT
Posts: 104 |
I run mine at 32-35 psi and have a best of 2.04 60' time. There isn't any advantage to running lower pressure as the tires aren't designed to be run that way.
99 T-Red SVT #1634/2760 K&N filter Aussie Intake Pipe Pro-M 75mm & Optimizer B&M Edge Shifter Quaife LSD Borla Cat back MSDS Headers/sho-shop Y-Pipe Dynoed at 184.2 HP & 157.2 TQ 14.53@94.15
Posts: 1,071 |
Has anyone tried BFG drag radials? Are they made in our size?
I just got an extra set of rims, so I willl be buying some soon as well.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 1,071 |
Nitto drag radials $65 each at discount tire direct! free shipping
Posts: 1,036 |
Damn, sweet deal... but no cash! DAMMIT!
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
