Posts: 539 |
thank you...just picked them up...and mite buy me some new wheels too
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 460 |
Be careful. Our stock Differential / Tranny / Clutch was not made to handle that type of traction. I had a friend (type of car to remain nameless)that blew his half shafts with a clutch side-step on 555r's.
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
Posts: 1,071 |
I've got a quaife and driveshaft shop axles  my diff bit the dust a long time ago  Still got the stock clutch, so that'll be the next thing to go :rolleyes: But I agree, be very careful with stock drivetrain with drag radials.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 539 |
I have a quaife now and and installing a Ram super duty 6 puck full metallic clutch. So now i just have to wait for the drive shafts to go.
Posts: 460 |
How much (and how difficult) were the drive shafts???
Po-Jay
Posts: 1,611 |
Drive shafts aren't difficult to do, just expensive. Stage II's IIRC are around $500 for the pair. Stage III's (like mine) are around $900.
Rick
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
Posts: 3,223 |
THe Nitto's are down to 60 dollars at discount tire!
-Andy
Posts: 999 |
Originally posted by CB99SVT: I run mine at 32-35 psi and have a best of 2.04 60' time. There isn't any advantage to running lower pressure as the tires aren't designed to be run that way. Okay, I guess all the mustang guys who run their radials at 15-18 psi don`t know what they are doing? I run about 20 psi in mine at the track.
14.72@ 92.6 mph www.modularV8.com "CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
Posts: 7,329 |
Originally posted by svt2000: Originally posted by CB99SVT: [b]I run mine at 32-35 psi and have a best of 2.04 60' time. There isn't any advantage to running lower pressure as the tires aren't designed to be run that way. Okay, I guess all the mustang guys who run their radials at 15-18 psi don`t know what they are doing? I run about 20 psi in mine at the track.[/b]RWD vs FWD. No weight transfer to the tires with FWD. There is a major difference right there.
Posts: 1,682 |
Originally posted by svt2000: Originally posted by CB99SVT: [b]I run mine at 32-35 psi and have a best of 2.04 60' time. There isn't any advantage to running lower pressure as the tires aren't designed to be run that way. Okay, I guess all the mustang guys who run their radials at 15-18 psi don`t know what they are doing? I run about 20 psi in mine at the track.[/b]well.. considering you drive a contour... i would listen to what the "contour guys" have to say... not the "mustang guys". a mustang is a 2door rwd coupe, alot of mustang guys see good results running 3.73 rear end gears... that doesn't mean a contour would...
