Page 4 of 4 1 2 3 4
jiako Offline OP
i was just messing but that is not what we did. cause i used the svt lower and if you put the svt lower on the 3L heads it won't seal. we had to hog out the heads to match the ports make new injector seats and make a adapter plate that sealed the 2 together. i have already told ppl bout this but some ppl have no joking humor.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Don't worry about it Jaiko, just don't like secrets is all.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
N
N
How much did the 3L conversion cost? and who did the work?
Nick10@onebox.com
98 Svt/Silver frost
Reinforced engine mounts
B&M Shifter
KKM intake
custom exhaust
Stage 2 axles
Omp strut brace
Ground-control/koni suspension
Mirko front spoiler
Quaife "Waiting to be installed"
Pre 98 console
jiako Offline OP
Total price of project costed
engine 1000
R&R 1500
swaping of cams
and head work 1000
total 3500
W
W
Nice Work Jiako!
Let's see what you can do with some of those bolt ons. It looks like we hit the same initial HP with the same basic configuration. I used 2.5 heads but widened out the combustion chamber so that compression was about 10.3:1. This lends credibility to both our numbers since your swapped in 3L is supposed to have 10:1 compression.
Cool.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
Jiako,
You said you used the SVT UIM & LIM correct? Why didn't you just use the 3L UIM & LIM. I know About space constraints and all, but would there be any change in performance (better or worse) if one was to use the 3L UIM & LIM?????
98 SVT
3 liter COMING SOON!!!!
jiako Offline OP
because i wanted to retaint he use of IMRC. In the 01' engines they do not use it
I
I
Sheesh, I got flamed to hell for that post. Good thing I don't check the board often... Course I'm sunburned today, so maybe it's about time I read this flaming. Now, since I'm finally responding, maybe to counter some of the flames... This should be fun. smile First thing, 190 horse at the wheels isn't bad, 180 ish torque at the wheels isn't bad either. But from the post, I (course I had just glanced) read it as a 3L conversion, in which case, that wasn't going to impress me. I've heard a lot on this board about the monstrous gains the 3L conversion yeilds, though rare to see the conversion, and at 193 horse I think it was? well, stock, the SVT's get around there at the crank, depending on year. Figure with mtx, you'd see around 150-170 at the wheels, depending on the vehicle, and how lucky you were with your car's quality. Means between 20 and 40 horse gain. Useful gains, but didn't seem awe inspiring considering all the raves about the 3L. Now, I didn't notice it was a prep for a larger change to come, I misread cause I skim things. Nothing like being jumped on for skimming over a post. :p And who was it that commented on the "massive" V8 to power my car? At 279 cubic inches (2 less than Ford's 4.6) I'm on the relatively small side of the V8 market. At near 300 horsepower at the crank, my 4.6 is one of the more efficient V8's on the market, power wise, though not the most efficient. (Not sure who carries the most efficient hp/liter ratio in the V8 market, and not going to fake it.) And to who decided it'd be fun to call me ignorant because I wasn't terrified of 190 horse at the wheels, sheesh. Someone also mentioned that the 190 horse 180 torque would move the contour around rather well, and that they didn't need the V8 my big car needs. No kidding, at 2 tons, my baby's no lightweight. smile Tons'o fun. :p I like the numbers to start, but they're not real impressive. Yet smile Good luck on the rest of the work man. (I'm not interested in a flame war, especially if I enter it sunburned. :p )
Words of wisdom...
-I'm too old for this sh*t.
-Dirty jews have well laundered money.
My car: Alyssa
1997 Cadillac Eldorado
Silver w/ Black half top
Ravin mufflers
Modified airbox and MAF
Rockford Fosgate 258 Watt multi channel Amp
Rockford Fosgate 9300X Punch Headunit, MP3 disc, with 8 CD changer.
Pair of 12" Boss 250W speakers in an oversized box
14.730 sec @ 95.79 mph in overdrive.
DYNO! 236.2 FW STD Horsepower
292.8 FW STD torque
Page 4 of 4 1 2 3 4
Moderated by  mbb41_dup1
