Posts: 191 |
Well, I finally got my Eldo dynoed, and finally got round to posting it. 236.2 horsepower, 292.8 torque. STD Ath the wheels. Assuming a theoretical horsepower loss of 25% due to automatic tranny, likely have 285 Horsepower at the crank, and a 5% loss of torque (numbers being told to me as average losses through fwd automatic trannies, feel free to correct me if these estimates are off) 315 torque at the crank. Those crank figures are educated guesses, tis all, the STD wheel power is accurate though. Also learned a slightly odd fact, though maybe not so odd. 2nd gear will take my car to 90 mph. I hadn't really noticed that. Ah well, tis my dyno test on a 1997 Cadillac Eldorado (base model) with just a set of high flow mufflers, all else stock. Enjoy contour buddies.
Words of wisdom... -I'm too old for this sh*t. -Dirty jews have well laundered money.
My car: Alyssa 1997 Cadillac Eldorado Silver w/ Black half top Ravin mufflers Modified airbox and MAF Rockford Fosgate 258 Watt multi channel Amp Rockford Fosgate 9300X Punch Headunit, MP3 disc, with 8 CD changer. Pair of 12" Boss 250W speakers in an oversized box 14.730 sec @ 95.79 mph in overdrive. DYNO! 236.2 FW STD Horsepower 292.8 FW STD torque
Posts: 656 |
please my huffy puts it out better then that.
no man good numbers. but you car cost 2 times more then ours did brand new so i would expect more then us. good job thou. oh yeha i runn all rockford audio to.
Michigan CEG BenTonEdge@aol.com **DEAD** Dec26 01. 96 2.5 Gl dessert violet. mystery mod, gutted cat. no res. craked secondaries. custom air box. And a good old CEL Oh you want to know
Posts: 7,329 |
What was the humidity and elevation when/where you got the dyno done? That's a pretty large FWD torque number... hmmmm torque....
Posts: 716 |
Originally posted by DemonSVT: What was the humidity and elevation when/where you got the dyno done?
That's a pretty large FWD torque number... hmmmm torque.... Sea-Level, Florida Humidity, ~60Degrees, at the Siboney Turbo Center in Orlando (Home of THE Turbo SVT. -Chris
Chris Hinds AIM:CJ111010 1998 Contour GL Duratec 5-Spd #565/???? 15.610 @ 89.62mph And I payed for it all myself
Posts: 191 |
Don't think I'm all that special Demon... your torque is more low end than mine. I don't get that 295 until about 4000 rpm....
Posts: 2,848 |
I thought the V8 Northstars have 300hp/tq?
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 586 |
Cadillac Cadillac Cadillac Syle.
Posts: 191 |
Depends on the particular package. I have a base model, 275 horse at 5250, 300 torque at 4000, any *T* models, ETC, DTS, STS, etc, have the 300 horse at 5600, 295 torque at 4250 if I recall. I know the hose and torque on both. I know at what rpm's on the 275/300 version. I'm not positive on the 300/295 revs. I do know that the 300 horse version does rev higher though. Either way, tis a fun motor to have. But as you see, either way, everything's high end. No low end torque sadly.
Posts: 2,809 |
wish my cars had that tourque... :p
Posts: 191 |
Wish my car didn't weigh 4000 lbs.... It needs to torque to get rollin.
