Page 2 of 2 1 2
#397053 02/21/02 03:02 PM
The correction factor, shown as CF=x.xx in the dyno plots has a HUGE effect on the overall result of your dyno pull. So coming on here and saying "My SE makes more power/torque than your SVT is not a true statement. Unless you ran as the same dyno with the same EXACT weather conditions and thus same exact CF number, then you cannot compare dyno numbers ever. Like it or lump it, that' the fact, Jack!
Dyno's are good for before and after comparisons if they are done on the same dyno with the same consditions, other than that you cannot use them for any other type of comparison.
I could easily show you my SVT make 250hp at the wheels by messing arounf with the CF number.
All that said, I can almost guarantee that Steve's A/F ratio is messed up seeing as he has no fuel/spark compenstion for his mods. If he were to fix this, he would definitely improve his numbers without a doubt.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#397054 02/21/02 04:10 PM
Originally posted by IndyTour:
Lets see I added the 180 removed ShoShop y-pipe and gutted the pre-cats and went from 136 tq to 156 tq and went from 142 to 160 hp on a stock SE. The KKM did virtually nothing.
18 hp and 20 tq from freeing up the exhaust and removing y-pipe, running real lean 13.9 WOT.
I kindly disagree about the 180 degree bend.
That's very interesting data, because many stock non SVT duratec v6's baseline around 150lbsft of torque to start. Hmm, computer code related too? A number of the torque losses I have seen, from removing the 180 bend were with SVT's but again, that is not all, just some of the ones I have observed.
#397055 02/21/02 06:57 PM
On the 180 degree bend note. IIRC Mazda dyno tested it to improve midrange torque as well.
So did MSDS when they were testing out Y-pipe designs.
I think a Y-pipe without the 180 degree bend may make more torque below IMRC point with a chip, but I noticed a slight dip in my graphs from 4200-5000 that a lot of other SVT's do not have. That's even chipped.
Now that could be something you can tune out with an S-AFC
Maybe I'll have to dyno with a Y-pipe with the 180 bend in the near future... laugh
2000 SVT #674 - Check it out!
#397056 02/25/02 05:52 AM
i dyno'd the same thing on mine... kkm vs. stock = very small difference...
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
#397057 03/03/02 06:09 PM
Makes sense...Kinda....because if you take away some backpressure, doesn't torque usually go down?
Ryan
98.5 Silver Frost Tour SVT 5979/6535
Born: May 15, 1998
Some Mods, still not fast enough..
90 Black SHO
SVT Performance.Com
Page 2 of 2 1 2
Moderated by  mbb41_dup1
