Posts: 508 |
While doing "spirited" driving...what RPM are you guy's shifting at??
Guess what I'm trying to get at is..the powerband on our cars, what RPM does it peak at? (peak HP)
NP-T Speed Factory Intake Magnaflow Race Canisters NP-T Sniper Intake Pipe Optimized 4.6 GT TB Vision Driving Lights Lo-Tek Pillar Pod FMS Blue Wires Clear Corners Short Shifter Side Markers Bullit Door
Posts: 1,071 |
Redline  actually 7500 rpm in my case since my chip bumps up the redline The SVT motor makes power all the way to 7000, so might as well use it.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 7,329 |
A few rpms before fuel cut. like 2... Right to redline, but not close enough to hit it.
Posts: 1,041 |
I had a chip put in that should have bumped the fuel cut-off. So how do I know they really raised it up to 7500, just push the gas till it drops in power?
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 446 |
From 2nd, fuel cut off is just the right amount of forward motion to depress the clutch and shift to 3rd
Posts: 424 |
My A'pexi shows 7,5xx, rev limiter adjusted on chip program. Most dyno graphs show that SVT's make max hp around 6,750 to 6,900(haven't seen a dyno with a raised limiter), but as Demonsvt has stated before "Shifting at a higher rpm will leave you in the sweet spot of the next gear". I can vouch for this since 1st to 2nd gear change on my car leaves about 15 feet of rubber with 215/45/17 Nitto's.
2000 SVT silver/blue #1699 of 2150 14.793@94.88 Sho-Shop off road y-pipe for sale($75)
Posts: 44 |
Posts: 3,950 |
At 6K RPM on my Zetec ATX. I have no choice.  I also have a chip though.
Posts: 785 |
why do you all shift so low on your ZETEC,Cheko and LoCoZetecSE ? i take my ZETEC all the way to the red line. i feel a nice and steady pull all the way thru...
Red '97 GL Sport MTX IVELISE ================================== "Let every nation know, whether it wishes us well or ill, that we shall pay any price, bear any burden, meet any hardship, support any friend, oppose any foe to assure the survival and success of liberty." John F. Kennedy
Posts: 785 |
forgot to add that i take it to red line from 1st to 4th gear...
