#396606 01/15/02 11:26 PM
I'm curious, and don't know much about this.. yet smile
Has anyone ever dyno'd multiple times _without_ making changes? say on the same day, or perhaps like a week later?
There is a point to this question...
T-Red SVT E0 #2321 of 6535
#396607 01/15/02 11:40 PM
yes, results vary. graph can vary too depending on what happend during the run. its just a measuring tool, subject to error like anything else.
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
#396608 01/16/02 01:55 AM
Sure have. With my most recent runs, there were 2 done right after one another, several times. The first run of the 2 was always higher by typically 2 HP & TQ due to the intake being warmer on the second run. The car was then turned off, a fan placed on the engine for about 10 minutes, then 2 runs done again - with the same HP & TQ spread.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
#396609 01/17/02 08:55 PM
That sounds pretty reasonable. Any feeling for how well the temperature/atmoshperic pressure compensation works?
EDIT: Also, is there any sort of standard or reference that these things are calibrated to to ensure some sort of consistency from one shop to another?
#396610 01/17/02 09:09 PM
AFAIK, Dynojet uses the same correction factors on their machines, so as long as you stick with Dynojet, city to city, you should be consistent. I'd imagine other dyno makers would do the same. As far as temperature and that it's tough to tell a difference, but if I was to comment, I'd say I may have gotten (and seen) better numbers in the summer, meaning the correction factor would be overcompensating ... but by only maybe 2-3 HP.
Moderated by  mbb41_dup1
