Page 2 of 3 1 2 3
#39637 03/09/02 03:40 AM
H
hanknum Offline OP
H
I was thinking around 10mm, maybe 15mm. I don't think that that is excessive...and as long as the studs are long enough.
#39638 03/09/02 03:56 AM
I have already had 2 studs break on my 2 front wheels.
Not sure why but I wouldn't suggest putting too much more stress on them as they seem to be weak. Might want to replace them with a strengthened set if thats even possible.
Later
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#39639 03/09/02 03:57 AM
10 or 15 wont work without longer studs. 5mm is the absolute longest I'd go on the stock pieces. I'm also using a lug nut that doesn't have the big bottom flange like the stock one so mine goes farther into the hole and gains back about the same amount of threads that the spacer took. You can barely start the stock lugs with the 5mm spacerr FYI.
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#39640 03/09/02 04:02 AM
JVT Offline
Shouldn't happen that often. IIRC, your Spiders are lugcentric, so make sure you torque down the wheel while it's in the air, or just barely touching the ground.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#39641 03/09/02 04:17 AM
You either need to change out the studs for longer ones, or check with someone like H&R, they have spacers that have there own studs!
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
#39642 03/09/02 09:21 PM
Just my 2 pennies, here...
H&Rs thicker spacers include their own studs, IIRC, but the thinner ones, like the 5mm, do not.
We had a guy at an autox event last year lose a wheel in one of the turns. Not sure how much damage he did to the brake disc, etc. Anyway, he was using spacers, and I'm not sure he had them on correctly, but the buzz seemed to be that if you use them, you need to take extra care. Longer studs are available, and perhaps not a bad idea.
"Function before fashion."
'96 Contour SE
#39643 03/09/02 11:35 PM
H
hanknum Offline OP
H
Definitely!
#39644 03/10/02 12:52 AM
Originally posted by JVT:
[b]I have already had 2 studs break on my 2 front wheels.
John[/b]
Yea I was actually surprised they broke. At the same time as well, on two different wheels. It was shortly after I had my tires balanced and rotated. So I went back and complained and had them replace the studs for free.
They didn't like it too much but I think they warped my Front Rotors at the same time. I replaced them so I guess they got off easy. That would have been alot harder to prove I guess.
Needless to say that was the last time I went there or let someone use a air gun to tighten my wheels. Now I always watch them tighten with a torque bar. wink
Still I didn't think the studs should have broken that quick. I guess they tightened them pretty tight. Or it could have been something else??
Justin
1998 Black SVT
#39645 03/10/02 10:50 PM
can somebody explain to me how these wheel spacers work?
Jim Hahn
1996 T-Red Contour SE
2002 Black Mazda MP5
Latest mods: sho shop off road y-pipe
#39646 03/11/02 07:07 AM
I had some 15mm spacers at one point with longer studs. It did look cooler but it was hell on the rear tires, they would scrape the top of the fender.
On the track it did feel like it did help some, but was a MAJOR PITA trying to mount wheels that were hubcentric. I got to tired of having to check them, torque steer, make sure they were centerd, torque steer, had to check the studs, torque steer, inspect the hub... blah blah blah blah... torque steer
beyondloadedSE - They are just like a giant washer between the hub and the wheel. Gives your car a 'wider stance' supposed to increase handling... Very popular in europe for some reason... smile
Dave
Originally posted by hanknum:
Has anyone put on any wheel spacers on their car to increase the track and bring the wheels out more flush with the body? Would this change the alignment? Would this put any more stress on any part of the suspension?
TIA
Henry
'00 SVT Contour
'78 308 GTS
'89 Katana 600
David Zambrano
svt_mondeo at yahoo dot com
CSVT E1 #4808 - soon to be 400hp
You get what you pay for. All advice here is free.
http://www.geocities.com/svt_mondeo- my homepage
Page 2 of 3 1 2 3
