#396295 11/30/01 06:19 PM
W
W
Heres the dyno for the SVT, bone stock:
And heres the Dyno for my car:
91 BLACK MTX
Some mods, nothing worth mentioning.
0-60MPH=6.28 sec
1/4 Mile=14.74@99.1MPH
Brad's Memorable Quote from DePalma's 312 U.S. History Class
DePalma-Refering to U.S. citizens, "What other citizens when asked the question in the 1700s 'Who want's to fight the best military in the world?' respond with a enthusiastic YEAH!!!!!!!!!!!"
#396296 12/06/01 02:50 PM
91!
What car is that cause they didn't make a Contour in 91 and it says 167bhp not 187bhp.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#396297 12/06/01 04:05 PM
I'm gonna take a wild guess and say it's a mustang...and his friend or whoever he dynoed with has the SVT...
1995 Probe GT ATX TOO MANY MODS
1999 Cougar V6 MTX
Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed)
Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress)
Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress)
Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues)
Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires smile...
#396298 12/06/01 04:11 PM
1
1
Originally posted by Andy W.:
91!
-Andy
"PLATES: SHO GN 91
SHOCAGO MEMBER "
Hmmmmmm - you think he might drive a SHO? smile
#396299 12/06/01 07:16 PM
W
W
Yeah, the top one was on the old mans Contour SVT and the bottom was on my SHO
The torque is not listed on either though.
91 BLACK MTX
0-60MPH=6.28 sec
#396300 12/07/01 05:05 PM
Not bad Not bad wink How's the motor? I mean 60k and everything up to date??
Ryan
98.5 Silver Frost Tour SVT 5979/6535
Born: May 15, 1998
Some Mods, still not fast enough..
90 Black SHO
SVT Performance.Com
#396301 12/08/01 06:30 PM
W
W
60K has been completed. The besides paint and 1 spot of surface rust the car is absolute mint. Engine is just as strong as when it left the factory if not stronger and the trans is fine.
91 BLACK MTX
0-60MPH=6.28 sec
Moderated by  mbb41_dup1
