Kev, I have always had really good luck reseting mine after mods. I had differences with the Y pipe and the chip. I guess its something you can try ![smile smile](/ubbthreads/images/graemlins/default/smile.gif) Yes OBDII is a learning operation computer. Some times I like to get a fresh jump start ![laugh laugh](/ubbthreads/images/graemlins/default/laugh.gif) Good graph and good power your pushin Originally posted by I-Dom-In-8: I havent Reset the Pcm since i got all the mods. I though that the Pcm would learn it as i go. I will do this though. I also havent cleand the Maf something i will also do.
Odd at no dip at secondary activation. In power or A/F ratio. Cleaned your intakes? Are the secondaries cracked?
Again i havent cleand my Intakes and no the Secondaries arent cracked. Is this a bad thing that ther was no Dip.
Thank you for your Time man. The reason i wanted to ask you is i know you know your Sht. I give ya lots or props man. Thanks again for the info
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
