Posts: 104 |
Well I added the sho-shop off road y-pipe so I went backto dyno to see what kind of gains I got. The weather in Houston was really good today and I was expecting decent numbers. The corrected numbers are 184.2 hp/ 157.6 tq but the actual horsepower was 189.1 because of the 70 degree temp and 20% humidity. I think this is a first for me to lose power with the correction factors but oh well I am pretty happy with the corrected numbers. The y-pipe added between three and four horsepower through the run.
99 T-Red SVT #1634/2760 K&N filter Aussie Intake Pipe Pro-M 75mm & Optimizer B&M Edge Shifter Quaife LSD Borla Cat back MSDS Headers/sho-shop Y-Pipe Dynoed at 184.2 HP & 157.2 TQ 14.53@94.15
Posts: 7,329 |
Awesome numbers!!!
Post some graphs... Want to see the curves...
Posts: 2,156 |
Sam 1998 Contour SVT #180 1/4=14.2 @ 101.17MPH
AOL users = PhatSVT _ _ _____________ _ _
1986 Mustang GT 12 second club
Posts: 3,421 |
Was that Y-pipe with the High flow cat or catless one.
Posts: 104 |
I will have to buy a scanner and send them to someone who can post them for me. I may pick one up in the next couple of days so everyone can see the graphs.
Posts: 2,847 |
I thought you had to use the MSDS Y-pipe with their headers? I've also heard they work better together. Why are you still using the SHO shop pipe? Kinda curious about this.
Posts: 104 |
I used the Sho-shop because the guy who I bought the headers from in the classifieds neglected to mention that he had already sold the MSDS Y. I had the headers and my Quaife installed by Terry Haines and we discussed the y-pipes it was his opinion that the sho-shop y-pipe would flow better so rather than trying to find an MSDS-Y I used the Sho-shop. I think the dyno that shows gains with the MSDS-Y over the Sho-shop is misleading because different cats were used with each Y-pipe.
Posts: 2,847 |
I didn't know about the differences in the cat in other dynos. Makes the results seem more like what they want you to believe. Either way, those are definately some nice numbers. I am just imagining how my numbers woudl respond to a set of MSDS. I think I will put it further down the list and worry about which direction of travel I should pick, chip/EEC Tuner/Apexi.
Posts: 2,631 |
Nice numbers... I got some good number off of my tour when I put the off road Y on her. 10hp 6tq... I was not making the power you were Great job though!!! Originally posted by CB99SVT: Well I added the sho-shop off road y-pipe so I went backto dyno to see what kind of gains I got. The weather in Houston was really good today and I was expecting decent numbers. The corrected numbers are 184.2 hp/ 157.6 tq but the actual horsepower was 189.1 because of the 70 degree temp and 20% humidity. I think this is a first for me to lose power with the correction factors but oh well I am pretty happy with the corrected numbers. The y-pipe added between three and four horsepower through the run.
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Posts: 972 |
hey, wtf happened to my post??
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
