"I think that the MAF is being blamed unecessarily for restriction when it is above all the cylinder head valves that are the restriction."
Perhaps but I do not think so. The valves are 32mm. If you recall the technical paper on developing a 2.0L Duratec Touring car motor that was on the forum a few months back - they used 31mm valves or 33mm valves (got same power with each - about 231 HP crank). This was at 8000 RPM but it was with a 2L which can draw less air - at 7000 RPM the 2L made 200 crank HP. The SHO shop 3L makes 229 FWHP (about 270 crank HP) with stock 2.5L 32mm valves at 7000 RPM. So, I would say the 2.5L (would make power in between the 2L with 31mm valves and the 3L with 32mm valves or between 200 and 270 HP or 235 crank HP at 7000 RPM- about 195-200 FWHP.
OK, is this pretty rough but if anybody has better data, I would like to hear. I personally think other restrictions in the intake come in to play first : the butterfly valves (turbulance), the t.body (perhaps at above 180 HP), the MAF meter (turbulance), and probably what Terry said about the initial portion of the upper intake and the T split.
