#396038 11/06/01 02:51 AM
CB99SVT Offline OP
I spent last week hanging around Rockford Michigan with my car in Terry's shop. He installed my Quaife and MSDS headers (stock Y-pipe) so today I made a trip to the dyno to find out the news. The peak numbers aren't that great but below 5200 rpm there is a big difference in the numbers. I really think the stock y-pipe is killing the top end power but I won't know for sure until I change it out. I am going back to dyno again tomorrow to see if the Borla I installed tonight helps out. If someone could tell me how to post the graph I will try and get it scanned so everyone can see how it looks.
New Max power 178.5
Old Max power 174.9
New Max torque 155.5
Old Max torque 151.2
99 T-Red SVT #1634/2760
K&N filter
Aussie Intake Pipe
Pro-M 75mm & Optimizer
B&M Edge Shifter
Quaife LSD
Borla Cat back
MSDS Headers/sho-shop Y-Pipe
Dynoed at 184.2 HP & 157.2 TQ
14.53@94.15
#396039 11/06/01 04:04 AM
I'd say that max power is pretty impressive. I certainly wouldn't complain! Can't wait to see what Borla and a good ypipe does.
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
#396040 11/06/01 02:52 PM
Msds y-pipe, Borla, and a Chip would do you wonders.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#396041 11/06/01 08:04 PM
The chip will probably help more than Msds y-pipe. I've got MSDS headers,y-pipe,Borla. Plus, KKM and 75mm Maf. My 98 e0 SVT is getting 179.3hp max and 156.7 max tq. I need to get custom chip to tune things up for these mods, but not bad considering I started with less hp than you guys with the later engines. laugh
98 evo 0 SVT
#2999 of 6535
Silver Frost/Midnight Blue
Lotsa bolt-ons
#396042 11/06/01 08:37 PM
CB99SVT Offline OP
I went back to dyno again today since I put the Borla on and the power went up a little more today. I think the most impressive thing is that the torque curve is very flat, 150 lbs/ft plus from 4000 all the way to 6250. I will probably put some kind of Y-Pipe and then worry about a chip, but for now I can live with 181.2 hp and 156.2 tq.
K&N filter
Aussie Intake Pipe
B&M Edge Shifter
Quaife LSD
Borla Cat back
14.53@94.15
#396043 11/06/01 08:47 PM
Very good numbers but you NEED better breathing. One dyno demonstrated a 5HP gain just removing the plastic cover on the drop in K&N. May want to check the new SHO-Shop intake with K&N filter, adapter, and heat shield for $99. And the Y-pipe should help alot (stock is the worst part of the exhaust IMHO). With a A/F optimization via dyno tuned chip, MAF optimizer, or Apexi-SAFC you should easily crank out 190+FWHP.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#396044 11/06/01 10:27 PM
CB99SVT Offline OP
I actually do have the filter housing off, the K&N is held on by two small bolts. I have a Y-Pipe on order now so I may head back to the dyno next week if I get the chance. I won't hold my breath hoping to get into the 190's but wouldn't it be nice!
K&N filter
Aussie Intake Pipe
B&M Edge Shifter
Quaife LSD
Borla Cat back
14.53@94.15
Moderated by  mbb41_dup1
