Posts: 104 |
I spent last week hanging around Rockford Michigan with my car in Terry's shop. He installed my Quaife and MSDS headers (stock Y-pipe) so today I made a trip to the dyno to find out the news. The peak numbers aren't that great but below 5200 rpm there is a big difference in the numbers. I really think the stock y-pipe is killing the top end power but I won't know for sure until I change it out. I am going back to dyno again tomorrow to see if the Borla I installed tonight helps out. If someone could tell me how to post the graph I will try and get it scanned so everyone can see how it looks.
New Max power 178.5 Old Max power 174.9
New Max torque 155.5 Old Max torque 151.2
99 T-Red SVT #1634/2760 K&N filter Aussie Intake Pipe Pro-M 75mm & Optimizer B&M Edge Shifter Quaife LSD Borla Cat back MSDS Headers/sho-shop Y-Pipe Dynoed at 184.2 HP & 157.2 TQ 14.53@94.15
Posts: 1,812 |
I'd say that max power is pretty impressive. I certainly wouldn't complain! Can't wait to see what Borla and a good ypipe does.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 3,223 |
Msds y-pipe, Borla, and a Chip would do you wonders.
-Andy
Posts: 268 |
The chip will probably help more than Msds y-pipe. I've got MSDS headers,y-pipe,Borla. Plus, KKM and 75mm Maf. My 98 e0 SVT is getting 179.3hp max and 156.7 max tq. I need to get custom chip to tune things up for these mods, but not bad considering I started with less hp than you guys with the later engines.
98 evo 0 SVT #2999 of 6535 Silver Frost/Midnight Blue Lotsa bolt-ons
Posts: 104 |
I went back to dyno again today since I put the Borla on and the power went up a little more today. I think the most impressive thing is that the torque curve is very flat, 150 lbs/ft plus from 4000 all the way to 6250. I will probably put some kind of Y-Pipe and then worry about a chip, but for now I can live with 181.2 hp and 156.2 tq.
Posts: 3,248 |
Very good numbers but you NEED better breathing. One dyno demonstrated a 5HP gain just removing the plastic cover on the drop in K&N. May want to check the new SHO-Shop intake with K&N filter, adapter, and heat shield for $99. And the Y-pipe should help alot (stock is the worst part of the exhaust IMHO). With a A/F optimization via dyno tuned chip, MAF optimizer, or Apexi-SAFC you should easily crank out 190+FWHP.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 104 |
I actually do have the filter housing off, the K&N is held on by two small bolts. I have a Y-Pipe on order now so I may head back to the dyno next week if I get the chance. I won't hold my breath hoping to get into the 190's but wouldn't it be nice!
