Posts: 2,708 |
The winner was the 88% humidity & the dyno itself. (everyone except todras & a guy with a badass GTI VR6 dynoed low)
Tim pulled 239fwhp I pulled 252fwhp... but something let go in the SC's driveline and the car had to be towed to another club members house where we bypassed the Blower pulley and i managed to drive home under normal aspiration. -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 4,319 |
Damn, that sucks Mark. Hope everything turns out ok....
1991 GVR4 Lots of mods done.
Posts: 1,296 |
Yeah and I broke my diff on the way home ![smile smile](/ubbthreads/images/graemlins/default/smile.gif)
Tim
Posts: 1,447 |
Great, that something to look forward to :rolleyes:
It's been extremely humid here in Cleveland too, I would assume the same weather was up there as well (70 degrees and you are sweating your a$$ off you know its humid)
Posts: 2,708 |
Tim, You broke your diff?? Damn we both had a bad weekend! -Mark
Posts: 3,248 |
Man, you guys BOTH had tranny problems same day?? THAT is a bummer.
BTW, does high humidity hurt or help power. Ive heard both - that humidity is water which is like water injection and air is denser. Does'nt seem intuative that it would help though.
Hope you guys get the cars sorted out OK. You are true Contour "pioneers".
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 2,708 |
I didn't have tranny problems. I have SC problems... Humidity hurts performance and it is not the same as water injection. Actually its like spraying the water on the filter and trying to suck it through...
-Mark
Posts: 567 |
for those that DID have diff probs...sounds like quaife is the way to go ![wink wink](/ubbthreads/images/graemlins/default/wink.gif) (I love mine!!)
CURRENT RIDE: 95 GL FORMER RIDE: 99 SVT ( www.mysvt.com) "You only live once, but if you lived my life, once would be enough." -Frank Sinatra
Posts: 1,841 |
I had problems with my car too that weekend. I had a BAD exhaust leak between my rear MSDS and one of the Tru-dual pipings. Bolt head sheared, but got it fixed... I know that wasn't as severe as Tim's or Mark's problems, but my dyno sucked too... BUT on the up side, I dyno'd 175 fwhp in 88% humidity, so I hope that means that I actually have some gains once the humidity clears and dyno'd again in the Fall.
"I sense much beer in you.... Beer leads to intoxication, intoxication leads to hang over, hang over leads to suffering....., suffering leads to the dark side." -Chineseman 3:16
Steve Chang 99 Silver SVT #196 "ExtrudeHone" Sponsored by Street-Concepts 174.2 fwhp @ 150.7 ft/lbs (218 hp @ crank) - Pre-Headers SVT/SHO Society Vice President XChang Designs
