#395090 06/24/02 07:54 AM
Just wanted to know if anyone has them or if anyone know's anything about them. I'm looking to gather some info on Leda's, I plan on purchasing these for my Tour'!
Thanks cool
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
#395091 06/24/02 09:54 PM
Leda has a very good coilover range, as does Truechoice . Expect to pay premium prices for the upper models in each range.
#395092 06/25/02 02:49 AM
2
2
I have the Leda's.
Currently I have the Oil set up with 325# front and 275# rear Leda springs.
The Oil set up is less harsh than the gas but I need adjust my spring rates for less lift off. Lift off is when your wheels leave the road due to hitting a bump or impact strip. The ride is OK and very sable at any speed.
The Gas set up with my Yoko A520's kept the car Nai!ed to the Road. I had Eibach 300# front springs with 250# rear. I had my corner weights balanced at 837.5 lbs on the rear and 1004.5 lbs on driver front and 948.5 lbs on passenger front with me in the car at 216 lbs and my 500 lbs sound system.
If I had the choice again I would get the gas set up and live with the loud noise over bumps.
I have not driven a car with Koni's. TrueChoice does a shorten Koni with Ground Control threaded sleeve to give you the same travel you get with a Leda. To get that Koni set up you will be paying more than the Leda gas set up. With the un-shortened Koni you can't lower your car without hitting the bump stops routinely due to reduce travel in the strut of a lowered car.
Enough words, Let me stop now smile .
#395093 06/25/02 12:58 PM
I have Ledas too.
Gas struts with a 2" shorter body, 24 point adjustable. 500lb/in front / 275lb/in rear Hypercoil springs.
#395094 06/25/02 03:57 PM
how much did you guys pay for the kits?
#395095 06/25/02 05:00 PM
A bit over 2K$.
#395096 06/25/02 05:01 PM
is that in US or Can dollars?
#395097 06/26/02 12:17 AM
US.
#395098 06/26/02 06:03 AM
Originally posted by Pascal:
I have Ledas too.
When did you get Leda's? Why? How's the ride? Do you have helper springs also?
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
#395099 06/26/02 06:13 AM
US.
ow....
