Page 5 of 5 1 2 3 4 5
#39478 03/15/02 05:42 AM
I run Valvoline Durablend (dino/synth) 5w30 & change every 3,000 (+/-500). I have considered changing to Mobil One, but never have done it. No real opinions one way or the other. Just commenting on what I use.
Someone said combo's (dino/synth) are bad. Is this true? Why?
Mark
#39479 03/15/02 05:58 PM
Mark
Most of the supposed advantages of synth (which I adhere to, btw) are lost if it is mixed with dino. Blends are a way to charge more for something that basically performs the same as dino.
As for extended drain oils, only AMsoil, Red Line, and IIRC Royal Purple are designed for extended drain, and even they recommend filter changes between oil changes.
"Function before fashion."
'96 Contour SE
#39480 03/15/02 09:54 PM
The real ripoffs are semi-synthetics, to which they impose no limitations as to what the minimum percentage of synthetic oil must be in a pint...
If you wanna run semi, blend it yourself, buy three name brand pints of dino oil, and three pints of mobil1 (SAME viscosity). You don't lose all the advantages of syn when you blend, although you muffle them somewhat. I would not go past 4000 miles with a blended oil.
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
#39481 03/16/02 07:35 AM
Originally posted by Milan007:
To those that use synthetic, how often do you change your oil? I use Mobil 1 and do it every 3500 mi.
I use Royal Purple and change every 3,000 miles!
Scotty Luther
rscottyl@onebox.com
AOL IM: RScottyL
Built 12/9/1999
2000 Contour SVT
Toreador Red/Prairie Tan
#832 of 2150
