#394729 05/26/02 04:40 PM
MaVRoCK Offline OP
I've tried to ask this question a few times before, but with no avail.
What are the differences, how do they ride, how much do they lower, overall quality etc...?
Also, I've heard that you should have an alignment done after they're installed and replace the original shocks or struts I believe???
Can someone help me out here? I'd really like to get mine lowered, and just want to do it right for the 'Tour!
Thanks guys,
-Brian
99 Black SE Sport ATX
Running on E1 SVT rims with Dunlop rubber
Pioneer DEH-P3100 CD receiver (2 channels of the amp blown, officially declared dead)
Pioneer DEH-P440 CD receiver
Pioneer TS-6865 6x8's in the front
Pioneer TS-6867 6x8's in the rear
Pioneer TS-WX121 Sub with a Pioneer GM352 amp feeding it
#394730 05/26/02 05:31 PM
I used eibachs with kyb struts. ride is nice and looks better. also get an alignment! i work at a shop that does them and i check mine like once a month after you lower your can it will never be perfect, although you may or maynot see tire wear.
#394731 05/26/02 06:13 PM
H&Rs: Front is dropped more than Eibachs, rear is less. H&Rs give a "raked" look (where the front seems slammed and the rear is a little higher). Ride is slightly stiffer than Eibachs.
Eibachs: Front is a little higher than H&Rs, but rear is dropped more. Eibachs give a more "level" look to the cars. Ride quality tends to be slightly more comfortable on tough roads.
Both companies are very respectable in suspension components.
Alignment is a must after lowering a car because toe will be out of specification. You can also now buy a camber/caster adjustment kit, which will allow you to change these specifications after lowering. Upgraded struts are also highly recommended because not only will they last longer than stock struts, it will save you time changing them when you change the springs, instead of having to replace them later! Good luck!
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
#394732 05/26/02 06:46 PM
F
F
Both sping companies are first rate, if your into autocross or all out racing I recommend H&R due to their compression being stiffer.
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#394733 05/30/02 12:43 AM
H&R and kyb gr-2 struts.. they work well
need an aussie bar though =/
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
