Posts: 926 |
Is it possible to change the Contour's 4 lug axles to 5 lug axles say from the Mustang or another vehical?
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 314 |
Sure, if you have the cash, anything is possible.
2000 Silver ZX3 1999 SVT Contour RIP 6/9/02
Posts: 1,559 |
The escape uses 5 lugs but I'm not sure if the dimensions for the Hubs are the same.
Posts: 926 |
Would the Escape be the best choice?
Posts: 1,559 |
It's the closest 5-lug relative the Contique/Cougar has. I'm not saying it will work but it might be worth looking at.
Posts: 2,166 |
I've been looking at this and I think the Escapes front and the Tarus rear would work. The Escapes rear is totaly different than our and the Taurus is more of a similar design.
Also I've spoke to SVT about this and they said that I should get the hub redrilled and to use F150 lugs that are stronger. But I think I would feel safer replacing the whole hub...
Posts: 926 |
Originally posted by David Z: I've been looking at this and I think the Escapes front and the Tarus rear would work. The Escapes rear is totaly different than our and the Taurus is more of a similar design.
Also I've spoke to SVT about this and they said that I should get the hub redrilled and to use F150 lugs that are stronger. But I think I would feel safer replacing the whole hub... Im suprised that SVT would even suggest that. But then again I doubt they like the idea of one of their cars having a 4 lug setup since they are used to the 5 lug.
Posts: 3,237 |
Why?
With the SVT Focus gaining popularity, wheel choices are getting better by the day.
I don't see the pro's of going to 5-lug being worth the hassle and money.
Posts: 361 |
Well if you get 5 lug from a stang's bolt pattern you can get Steeda Ultralight wheels But no one else do it
Posts: 314 |
Stang is RWD, you can't use most wheels designed for RWD on a FWD car, the offset is all wrong. It's the reason why you don't see "deep dish" wheels on a FWD car.
