Posts: 32 |
ok, took the 'tique in the other day to get the radiator flushed, and the mechanic told me, "FOUND THE L/SWAY BAR LINK LOOSE AND SWAY BAR HAS PLAY-BOTH SHOULD BE REPLACED" to the tune of $300. i think they just feeding me a line of **** and want to charge me 300 bucks to change the $10 sway bar linkages. any guesses/comments/experiences like this?
1995 Mercury Mystique GS 2.0L Zetec, MTX 10% dents all around its not my fault its teal!!! it was cheap!
Administrator
Administrator
Posts: 702 |
On a 95, very likely true that it was needed. But $300 is highway robbery.
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 1,559 |
Agree with Lance takes about an Hour to do both so it should cost
75 labor and maybe 50 for parts?
Posts: 132 |
Is the sway bar link the piece that connects the sway bar to the strut? If so what happens to them that causes them to need replacing? Symptoms?
95 T-Red SE MTX Eibach springs, Custom cat-back exhaust, Cross-drilled front rotors, Momo air race leather shift-knob, Kenwood head unit, Kenwood 600w amp, 2 12" Infinty's, 18" Tantrums w/ Yoko Paradas, SCA CAI
Posts: 5,805 |
Front suspension 'clunks' is the symptom,can reach round behind the wheel an feel if its worn,some upgraded a/market links have grease fittings,by the links & diy.......
Posts: 4 |
this maybe a stupid question.But are you refering to a clunk/sound like the springs hit the top of the fender when you go over a bump or pot hole. i ask because i had front end work done and when it came back from the dealership it does as i described above.I took it back and they told me it is perfectly normal and couldn't find a problem! it never did this prior to the work. thanks Originally posted by Terry Haines: Front suspension 'clunks' is the symptom,can reach round behind the wheel an feel if its worn,some upgraded a/market links have grease fittings,by the links & diy.......
