Posts: 334 |
There is a how to in the how to section on the Tranny fluid. I've done it, its easy 1 hour or less. Mobil 1 Synthetic ATF with Ford Friction Modifier. BEST BET. Ask anyone who has done it. Also really good protection for your tranny.
98 Contour V6 MTX KKM/Niehoff Wires/Bosh+4/Mobil 1 Oil/Tranny/Pioneer CD/Speakers Predator Alarm...more 2 come!
"Dana, if by accident, I dropped an 7mm rachet inside your secondaries your engine would be ok? right?" "Trust me if I could go back and change, I would be stuck in the past" MartinS
Posts: 91 |
Originally posted by MartinS: . I've done it, its easy 1 hour or less. Mobil 1 Synthetic ATF with Ford Friction Modifier. BEST BET. Ask anyone who has done it. . Ok, I'm asking, what difference did it make when swiching from non synthetic to the Mobil 1 Synthetic ATF with Ford Friction Modifierfull mix?
1998 Contour 2.5 Non-SVT (ATX) SHO Y-Pipe K&N Drop-in
Posts: 5 |
Originally posted by SonOfABoss: It's a waste of money, if you use Syn oil just use 1 qt with your normal oil, say 4 qts of penn and 1 qt of penn syn, or mobil drive clean and mobil syn. Putting all syn oil doesn't do anymore for your engine than just 1 qt in with your normal oil. Or just add a bottle of duralube or slick 50 in with your normal oil, because all syn oil is is just normal oil with a treatment in it, like duralube or slick 50. Just my 7 cents ================================================= Lets see your credentials to make such a dumb comment...... =================================================
I Live in NJ but I Bleed Buffalo Red, White and Blue!
Posts: 2,848 |
I don't know if it's in the "standard" owners manual, but it is in the SVT supplement book for sure. So far, I think I'm going to stick with mobil 5w 30 and Motorcraft filterrs.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 3,419 |
Originally posted by More-Power: Ok, I'm asking, what difference did it make when swiching from non synthetic to the Mobil 1 Synthetic ATF with Ford Friction Modifierfull mix? Night and day difference in shifting. A lot smoother and less "mushy". Much easier to shift when cold. The Friction Mod is also good for synchro life.
Posts: 852 |
I change my mobil 1 every 6000miles, sometimes 8000. I was worried with all the lube shop owners saying it would harm my engine (what did you expect, no really...)
So i did an oil analysis, and at 9000 miles, my oil (amsoil 5w30) was still in spec. Pure one filter. Foam air filter (that accopunts for alot, filtration is better than K&N or stock)
So if you're gonna dump at 3000, I would say mix 50/50 with conventionnal oil. If not, just go 5 to 6K with syn. Comes out the same price wise, and its much less hassle. Cleaner engine too.
BTW, leaks on high mileage engines are caused by accumulated crud from the dino oil. Crud shields seals from the oil, seals dry and shrink. then when you add synthetic oil, it cleans the crud, and exposes the seal. If the seal has dried out too long, it cannot recover its original shape or size. Then you have leaks... And if you have a seeping leak, it will be worse with the same grade syn, because of lower viscosity...
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 216 |
Really glad this post came along, while I'm using castrol GTX right now due to being overwhelmed by credit card bills, my next oil change will be Amsoil with an Amsoil filter, I did a good deal of reading up on this and it seems to be the best combo. Amsoils filters apparently filter out much finer contaminants, and their oil is rated to last 7500 miles!
2000 Contour SE V6 ATX (White) K&N Moose fixed finally! Dunlop SP Sport A2's Sylvania Silver Stars (low and hi) Lots more coming!
Posts: 499 |
Speaking of the seeping oil leaks.... What all can leak oil? I started this thread, and was wondering, since i changed to synthetic and nothing has started leaking yet.. But like i said, what would leak? Which seals do you think would be corroded?? Thanks!
Posts: 45 |
I run a service center. I use Pennzoil Syn. I change my oil every 3000-3500 miles. The only real difference in the major brand (Penn., Castrol, Mobil 1, Val)synthetic oil's are minor differences in detergents. I have found a slight increase in fuel mileage, as well as faster preasure on start-up. I find it very funny that some people belive that a synthetic oil(read: man made) is just conventional oil(read: from the ground) with Slick 50. I have always thought that engine additives are not needed if you properly maintain you engine. I doubt Robert Yates or Roger Penske ever poured a jug of Motor Up into a motor that made some noise during a pit stop.
Posts: 45 |
Also,be cautious of extended oil change intervals. Most filters become inafective after 3500-4000 miles. Once the filter becomes clogged, the oil bypasses the filter. This is bad. The additives in most oils also wear out after 4000-5000 miles.
