Posts: 1,559 |
Well "IF" you happen to be unlucky and have a car with a full tank of gas and time constraits then you can unscrew the passenger side bot a little to aid the movement of the Tank. I highly reccomend doing it with less gas in the tank. It moves better that way.
Try pushing one side into position first then using that leverage to push the other side in as well. It works like a charm.
Posts: 114 |
When I did my rear bar I had the car on stands and used a small jack to force it past the metal stone guard on the plastic fuel tank.
The stone guard was all that was stopping it going in on my Mondeo, not the actual tank itself- I take it the Contour has the same problem?
David Mondeo ST24 Information Site yr 2000 silver Mondeo ST24 V6 MTX mods: Custom alloy air intake using K&N RC-3250 air filter; Koni Sports shocks; rear 20mm Selbys sway bar; THF; EBC Greenstuff front pads, custom exhaust.
Posts: 1,445 |
Originally posted by Munson: - just kept pushing and pushing, and finally that bar went up into its new home.
-Kurt sounds like when i lost my virginity
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 407 |
Originally posted by goatis: Is there some secret to removing the old sway bar/installing new one without messing with the gas tank? theres no way in hell the bar can fit through that little space.. I don't want to mess with the gas tank.. boom! thanks I ended up pulling mine out the passenger side wheel well, but couldn't push the new one in that way ... I'd suggest you just pull HARD to get the old one out and PUSH hard to get the new one in. Count on busted-up knuckles.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 5,805 |
Disconnect the passenger fore and aft torque rod from the knuckle.....
