Page 1 of 5 1 2 3 4 5
#39438 03/04/02 03:50 PM
I just decided to start changing my own oil. I have had Penzoil Synthetic-Blend oil put in my car the past 4 oil changes.. Is it fine to switch to Mobil 1 tri-synthetic on my car? It has like 90,000+ miles on it.. Just wondering, thanks in advance
Paul
'95 Midnight Red SE V6 MTX
mods
Midnight Red Contour Pics
***car under construction***
#39439 03/04/02 06:38 PM
It's a waste of money, if you use Syn oil just use 1 qt with your normal oil, say 4 qts of penn and 1 qt of penn syn, or mobil drive clean and mobil syn. Putting all syn oil doesn't do anymore for your engine than just 1 qt in with your normal oil. Or just add a bottle of duralube or slick 50 in with your normal oil, because all syn oil is is just normal oil with a treatment in it, like duralube or slick 50. Just my 7 cents
~*TJ*~ 97 GL Sport Zetec
~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
#39440 03/04/02 06:51 PM
Go ahead and use fully synthetic, you should be OK. I would not use the semi-syns; they are a waste of money!
Dan B.
#39441 03/04/02 07:12 PM
Yeah, Synthetic is just a marketing gimic. It ranks right up there with the little stickers you throw on the back of cell phones to boost the signal.... :rolleyes: :rolleyes:
1991 GVR4
Lots of mods done.
#39442 03/04/02 07:18 PM
Master P
Master P
Now that right there is some of the funniest stuff I have read all year!
#39443 03/04/02 07:28 PM
Administrator
Administrator
wow, do you have to try to say stuff like this? Please, try to understand what you are talking about before making definative comments.
Synthetic oil is a far more consistant chemical composition oil than conventional, and is capable of offering the same protection at lower viscosities, creating less parasitic loss than a conventional oil.
Is it worth it? Depends on your budget.
Does it have noticable benefits? Yes.
Should you switch to synthetic on a higher mileage engine? You can always give it a try, conventional oils tend to swell gaskets and seals more than a synthetic, so occasionally a higher mileage engine will leak a little after switching to synthetic, but if your engine is in good shape, it shouldn't be an issue. And even if it is, you can always switch back at your next oil change.
It's all about balance.
bcphillips@peoplepc.com
#39444 03/04/02 09:18 PM
bwa-hahahaha.... snake oil too...
Ouch, ouch my sides hurt...
You should do stand up with a routine like that...
Really... I mean... You weren't serious right??? Man I sure hope not. That would just be sad otherwise...
2000 SVT #674 - Check it out!
#39445 03/04/02 11:03 PM
Said the same thing in a Zetec forum thread...
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=33;t=000922;p=2
#39446 03/04/02 11:12 PM
Yep I did say it in Zetec forum too, I have asked plenty of mechanics about it and that is what they have told me, if I am wrong, so be it. But I was just relating what I have been told.
More to come
#39447 03/04/02 11:19 PM
Thanks for the help :-) I will be changing it this evening on the ramps I've made from the MustangWorld forums (but 1 more step). Again, thanks for the info!
Paul
mods
